7812E 0061640
7812E 0061640
    BELDEN
    BELDEN - 7812E 0061640 - Networking Cable, LAN, Unscreened, Cat6, 23 AWG, 0.259 mm², 1640 ft, 500 m
7812E 0061640 数据手册
Part Number: 7812E Category 6 Bonded-Pair Cable Product Description Cat. 6 (250MHz), 4-Pair, U/UTP Unshielded, Premise Horizontal Cable, 23 AWG solid bare copper conductors, Polyethylene insulation, PVC jacket Technical Specifications Product Overview Environmental Space: Indoor - Euroclass Eca Suitable Applications: Horizontal and building backbone cable; Support current and future Category 6 and 5e applications, such as: 1000Base - T (Gigabit Ethernet), 100 Base - T, 10 Base - T, FDDI, ATM Physical Characteristics (Overall) Conductor Element AWG Stranding Individual pair 23 Solid Material No. of Pairs BC - Bare Copper 4 Conductor Count: 8 Total Number of Pairs: 4 Insulation Element Type Material Nominal Diameter Individual pair Dielectric Polyethylene 1.1 mm Color Chart Number Color Pair 1 White/Blue & Blue Pair 2 White/Green & Green Pair 3 White/Orange & Orange Pair 4 White/Brown & Brown Outer Jacket Material Material Color Nominal Diameter Diameter +/- Tolerance PVC - Polyvinyl Chloride Grey or Blue 6.1 mm Construction and Dimensions Min Elongation at Breakof Conductors: 10 % Min Elongation at Breakof Insulation: 100 % Cabling Filler Cross Web of Polyolefin Min Elongation at Breakof Jacket: 100 % Min Tensile Strength of Jacket: 9 MPa 0.3 mm Electrical Characteristics Conductor DCR Max. Conductor DCR Max DCR Unbalanced Between Pairs [%] Max. DCR Unbalanced Within Pair [%] 95 Ohm/km 4% 2 Ohm Capacitance Max. Capacitance Unbalance Max. Mutual Capacitance 1,600 pF/m 56 pF/m Impedance Nominal Characteristic Impedance 100 Ohm Delay Max. Delay Skew Min. Velocity of Propagation 40 ns/100m 60 % High Freq Frequency [MHz] Min. NEXT [dB] Max. Insertion Loss (Attenuation) Min. PSNEXT [dB] Min. ACR [dB] Min. PSACR [dB] Min. ACRF (ELFEXT) [dB] Min. PSACRF (PSELFEXT) [dB] Min. RL (Return Loss) [dB] Min. TCL [dB] Min. ELTCTL [dB] 1 MHz 2.1 dB/100m 75.3 dB 72.3 dB 73.2 dB 70.2 dB 70 dB 67 dB 20 dB 50 dB 35 dB 4 MHz 3.8 dB/100m 66.3 dB 63.3 dB 62.4 dB 59.4 dB 58 dB 55 dB 23 dB 44 dB 23 dB 10 MHz 6 dB/100m 60.3 dB 57.3 dB 54.3 dB 51.3 dB 50 dB 47 dB 25 dB 40 dB 15 dB 16 MHz 7.6 dB/100m 57.2 dB 54.2 dB 49.6 dB 46.6 dB 45.9 dB 42.9 dB 25 dB 38 dB 10.9 dB 20 MHz 8.5 dB/100m 55.8 dB 52.8 dB 47.3 dB 44.3 dB 44 dB 41 dB 25 dB 37 dB 9 dB 31.2 MHz 10.7 dB/100m 52.9 dB 49.9 dB 42.1 dB 39.1 dB 40.1 dB 37.1 dB 23.6 dB 35.1 dB 5.1 dB 62.5 MHz 15.5 dB/100m 48.4 dB 45.4 dB 32.9 dB 29.9 dB 34.1 dB 31.1 dB 21.5 dB 32 dB 100 MHz 19.9 dB/100m 45.3 dB 42.3 dB 25.4 dB 22.4 dB 30 dB 27 dB 20.1 dB 30 dB 155 MHz 25.3 dB/100m 42.4 dB 39.4 dB 17.1 dB 14.1 dB 26.2 dB 23.2 dB 18.8 dB 28.1 dB 200 MHz 29.1 dB/100m 40.8 dB 37.8 dB 11.6 dB 8.6 dB 24 dB 21 dB 18 dB 27 dB 250 MHz 33 dB/100m 39.3 dB 36.3 dB 6.3 dB 3.3 dB 22 dB 19 dB 17.3 dB 26 dB High Freq Table Note: Limits below 4MHz are for information only. Current Max. Recommended Current [A] 1.5 A Voltage Voltage Rating [V] 72 V Temperature Range Installation Temp Range: 0°C To +50°C Operating Temp Range: -30°C To +60°C Mechanical Characteristics Bulk Cable Weight: 41 kg/km Max Recommended Pulling Tension: 80 N Min Bend Radius During Installation: 52 mm Min Bend Radius During Operation: 26 mm Standards ISO/IEC Compliance: ISO/IEC 11801 Ed. 2.2:2002/A2:2010/C1:2011 CPR Euroclass: Eca CENELEC Compliance: EN 50173-1 Ed. 3:2011 Data Category: Category 6 ANSI Compliance: ANSI/TIA/EIA 568-B.2-1 (2002) Flammability, LS0H, Toxicity Testing ISO/IEC Flammability: IEC 60332-1 Burning Load: 575 kJ/m Part Number Variants Item # Color 7812E.011000 BLUE 7812E.01500 BLUE 7812E.01U305 BLUE 7812E.001000 GRAY 7812E.00500 GRAY 7812E.00B100 GRAY 7812E.00U305 GRAY Patent: http://www.belden.com/p © 2018 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be incompliance with EU RoHS(Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be instock at Belden facilities and in our Distributor's inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden's knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be incompliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
7812E 0061640 价格&库存
很抱歉,暂时无法提供与“7812E 0061640”相匹配的价格&库存,您可以联系我们找货
