8281B 0061000
8281B 0061000
    BELDEN
    #20 FRSFPE DBLB FRPVC
8281B 0061000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8281B Coax - Double Braided RG-59/U Type For more Information please call 1-800-Belden1 General Description: 20 AWG solid .031" bare copper conductor, flame-retardant semi-foam polyethylene insulation, tinned copper/bare copper double braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 20 Solid BC - Bare Copper 0.7874 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) FR Semi-Foam PE - Flame Retardant Semi-Foam Polyethylene 5.0292 Outer Shield Outer Shield Material: Layer # Type Outer Shield Material Coverage (%) 1 Braid TC - Tinned Copper 95.000 2 Braid TC - Tinned Copper 95.000 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 7.747 mm Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 75°C, 80°C Bulk Cable Weight: 117.568 Kg/Km Max. Recommended Pulling Tension: 747.298 N Min. Bend Radius/Minor Axis: 76.200 mm Min. Flexing Radius: 15.240 cm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG AWM Specification: UL Style 1354 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8281B Coax - Double Braided RG-59/U Type EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/13/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 59/U Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes - Black Only Suitability - Aerial: Yes - Black only, when supported by a messenger wire Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88281 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/m) 0.387158 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 68.901 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/m) 5.05274 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 32.4819 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 3.6091 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 0.9843 3.6 1.6405 10.0 2.6248 71.5 6.8901 135 9.843 270 14.4364 360 16.7331 Page 2 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8281B Coax - Double Braided RG-59/U Type 540 21.6546 720 25.5918 750 26.248 1000 33.4662 Max. Operating Voltage - UL: Voltage 30 V RMS 300 V RMS Max. Operating Voltage - Non-UL: Voltage 300 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. 75 +/- 1.5 Ohms Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, Using a 75 Ohm fixed bridge and termination. Minimum Structural Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 216 27 217 850 23 Sweep Test Sweep Testing: 100% sweep tested. 5 MHz to 850 MHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8281B 0021000 305 MT 37.648 KG RED C #20 FRSFPE DBLB FRPVC 8281B 0041000 305 MT 37.648 KG YELLOW C #20 FRSFPE DBLB FRPVC 8281B 0051000 305 MT 37.648 KG GREEN, DARK C #20 FRSFPE DBLB FRPVC 8281B 0061000 305 MT 37.648 KG BLUE, LIGHT C #20 FRSFPE DBLB FRPVC 8281B 0071000 305 MT 37.648 KG VIOLET C #20 FRSFPE DBLB FRPVC 8281B 0081000 305 MT 37.648 KG GRAY C #20 FRSFPE DBLB FRPVC 8281B 0091000 305 MT 37.648 KG WHITE C #20 FRSFPE DBLB FRPVC 8281B 0101000 305 MT 37.648 KG BLACK C #20 FRSFPE DBLB FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-27-2012 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
8281B 0061000 价格&库存
很抱歉,暂时无法提供与“8281B 0061000”相匹配的价格&库存,您可以联系我们找货
8281B 0061000
