Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
8404 Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable
For more Information
please call
1-800-Belden1
General Description:
20 AWG stranded (19x32) high-conductivity tinned copper conductors, polyethylene insulation, rayon braid,
tinned copper braid shield (85% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
4
19x32
Dia. (in.)
High Conductivity TC - Tinned Copper .037
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Material Wall Thickness (in.) Dia. (in.)
PE - Polyethylene
.016
.069
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid TC - Tinned Copper
85
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride .032
Overall Cable
Overall Cabling Color Code Chart:
Number Color
1
Clear
2
Black
3
Red
4
Green
Overall Cabling Separator Material:
Rayon Braid
Overall Nominal Diameter:
0.252 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +60°C
UL Temperature Rating:
60°C (UL AWM Style 2094)
Bulk Cable Weight:
46 lbs/1000 ft.
Max. Recommended Pulling Tension:
100 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
AWM Specification:
UL Style 2094 (300 V 60°C)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
Page 1 of 3
01-05-2017
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
VW-1
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
45
Nom. Inductance:
Inductance (µH/ft)
.2
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
23
Nom. Cap. Between Cond. in a Quad Config.:
Capacitance (pF/ft)
49
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
10.2
Nominal Outer Shield DC Resistance:
3.23
Max. Operating Voltage - UL:
Voltage
300 V RMS (UL AWM Style 2094)
Max. Recommended Current:
Current
3.1 Amps per conductor @ 25°C
Other Electrical Characteristic 1:
2/c 17 AWG equivalent DCR when connected to a 3-pin XLR.
Notes (Overall)
Notes: Quad connection scheme: The two blue wires (or wires directly opposite one another) are connected together to form one conductor, and similarly the two white wires (or
remaining wires) are connected together to form the second conductor.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
8404 060U1000
1,000 FT
48.000 LB
CHROME
Notes
Item Desc
8404 060100
100 FT
5.400 LB
CHROME
8404 0601000
1,000 FT
49.000 LB
CHROME
C
4 #20 PE SHLD PVC
8404 060500
500 FT
25.000 LB
CHROME
C
4 #20 PE SHLD PVC
4 #20 PE SHLD PVC
4 #20 PE SHLD PVC
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 05-14-2007
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 3
01-05-2017
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“8404 060100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+61.20070100+7.89505
