Detailed Specifications & Technical Data
METRIC MEASUREMENT VERSION
8424 Multi-Conductor - Four-Conductor Star Quad, Low-Impedance Cable
For more Information
please call
1-800-Belden1
Description:
20 AWG stranded (26x34) high-conductivity tinned copper conductors, EPDM rubber insulation, rayon
braid, TC braid shield (85% coverage), cotton wrap, EPDM rubber jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
4
26x34
Dia. (mm)
High Conductivity TC - Tinned Copper 0.9398
Insulation
Insulation Material:
Insulation Material
Wall Thickness (mm) Dia. (mm)
EPDM - Ethylene Propylene Diene Monomer Rubber 0.5842
2.1082
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid TC - Tinned Copper
85
Outer Shield Separator Material:
Cotton Wrap
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (mm)
EPDM - Ethylene Propylene Diene Monomer Rubber 0.9144
Overall Cabling
Overall Cabling Color Code Chart:
Number Color
1
Black
2
White
3
Red
4
Green
Overall Cabling Separator Material:
Rayon Braid
Overall Nominal Diameter:
7.468 mm
Mechanical Characteristics (Overall)
Operating Temperature Range:
-50°C To +90°C
Non-UL Temperature Rating:
60°C
Bulk Cable Weight:
90.780 Kg/Km
Max. Recommended Pulling Tension:
386.993 N
Min. Bend Radius (Install)/Minor Axis:
74.930 mm
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
Page 1 of 3
05-10-2011
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
52
Nom. Inductance:
Inductance (µH/m)
0.59058
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/m)
154.207
Nom. Cap. Between Cond. in a Quad Config.:
Capacitance (pF/m)
193.579
Nominal Velocity of Propagation:
VP (%)
52
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/km)
33.4662
Nominal Outer Shield DC Resistance:
DCR @ 20°C (Ohm/km)
10.4992
Max. Operating Voltage - UL:
Voltage
600 V RMS
Max. Recommended Current:
Current
3.2 Amps per conductor @ 25°C
Other Electrical Characteristic 1:
2/c 17AWG equivalent DCR when connected to a 3-pin XLR
Notes (Overall)
Notes: Quad connection scheme: The black and red wires (or wires directly opposite one another) are connected together to form
one conductor, and similarly the white and green wires (or remaining wires) are connected together to form the second
conductor.
Related Documents:
No related documents are available for this product
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
8424 010U500
152 MT
14.515 KG
BLACK
Page 2 of 3
Notes
Item Desc
4 #20 EPDM SHLD EPDM
05-10-2011
8424 010100
30 MT
3.084 KG
BLACK
8424 0101000
305 MT
29.030 KG
BLACK
C
4 #20 EPDM BRD EPDM
8424 010250
76 MT
6.917 KG
BLACK
C
4 #20 EPDM BRD EPDM
8424 010500
152 MT
13.835 KG
BLACK
C
4 #20 EPDM BRD EPDM
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 05-14-2007
© 2011 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications
described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not
ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express,
statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or
exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the
compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and
the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge,
information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide
for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not
to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC.
Page 3 of 3
05-10-2011
很抱歉,暂时无法提供与“8424 010500”相匹配的价格&库存,您可以联系我们找货
