8468MN 0081000
8468MN 0081000
    BELDEN
    CBL 15COND 18AWG
8468MN 0081000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8468MN Multi-Conductor - SpaceMaker Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (41x34) tinned copper conductors, fifteen conductors cabled, Polypropylene insulation, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 15 18 41x34 TC - Tinned Copper Insulation Insulation Material: Insulation Material Wall Thickness (mm) PP - Polypropylene 0.254 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.406 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 White 3 Red 4 Dark Green 5 Brown 6 Dark Blue 7 Orange 8 Yellow 9 Purple 10 Gray 11 Pink 12 Tan 13 Aqua 14 Light Green 15 Light Blue Overall Nominal Diameter: 8.814 mm Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Bulk Cable Weight: 150.308 Kg/Km Max. Recommended Pulling Tension: 1668.075 N Min. Bend Radius/Minor Axis: 35.306 mm Min. Bend Radius (Continuous Flexing): 88.138 mm Flex Cycle Rating: 1 Million Flexes Page 1 of 2 10-17-2016 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8468MN Multi-Conductor - SpaceMaker Audio, Control and Instrumentation Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Other Specification: UL Style AWM 2937 (300V 80C), NFPA 79 Flame Test CSA Flame Test: FT2 Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) 0.072 Nom. Capacitance Conductor to Conductor: Capacitance (pF/m) 48.559 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 21.327 Max. Operating Voltage - UL: Voltage 300 V RMS Put Ups and Colors: Item # Putup Ship Weight Color 8468MN 004100 100 FT 11.600 LB YELLOW 15 #18 PO PVC 8468MN 0041000 1,000 FT 108.000 LB YELLOW 15 #18 PO PVC 8468MN 006100 100 FT 11.600 LB BLUE, LIGHT 15 #18 PO PVC 8468MN 0061000 1,000 FT 108.000 LB BLUE, LIGHT 15 #18 PO PVC 8468MN 008100 100 FT 11.600 LB GRAY 15 #18 PO PVC 8468MN 0081000 1,000 FT 108.000 LB GRAY 15 #18 PO PVC Revision Number: 0 Notes Item Desc Revision Date: 09-29-2016 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 10-17-2016
8468MN 0081000 价格&库存
很抱歉,暂时无法提供与“8468MN 0081000”相匹配的价格&库存,您可以联系我们找货
8468MN 0081000
  • 1000+65.936771000+8.27179
