8502 0101000
8502 0101000
    BELDEN
    BELDEN - 8502 0101000 - HOOK UP WIRE, 1000FT, 20AWG COPPER BLACK
8502 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8502 Hook-up/Lead - (Type B) MIL-W-16878/1-PVC For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, PVC insulation. Covers insulated wire for internal wiring of meters, panels, and electrical or electronic equipment. Temperatures to 105ºC. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 20 7x28 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .010 Overall Insulation Overall Cable Overall Nominal Diameter: 0.058 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +105°C Bulk Cable Weight: 4.500 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2006 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-16878/1 MIL Spec Rating: 600 V, 105°C Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.500 Max. Operating Voltage - Other: Voltage Description 600 Vrms Mil-W-16878/1 Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient. 14 amps Put Ups and Colors: Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8502 Hook-up/Lead - (Type B) MIL-W-16878/1-PVC Item # Putup Ship Weight Color 8502 001100 100 FT 0.500 LB BROWN Notes Item Desc 8502 0011000 1,000 FT 5.000 LB BROWN 8502 002100 100 FT 0.500 LB RED 8502 0021000 1,000 FT 5.000 LB RED 8502 003100 100 FT 0.500 LB ORANGE 8502 0031000 1,000 FT 5.000 LB ORANGE 8502 004100 100 FT 0.500 LB YELLOW 8502 0041000 1,000 FT 5.000 LB YELLOW 8502 005100 100 FT 0.500 LB GREEN, DARK 8502 0051000 1,000 FT 5.000 LB GREEN, DARK 8502 006100 100 FT 0.500 LB BLUE, LIGHT 8502 0061000 1,000 FT 5.000 LB BLUE, LIGHT 8502 007100 100 FT 0.500 LB VIOLET 8502 0071000 1,000 FT 5.000 LB VIOLET 8502 008100 100 FT 0.500 LB GRAY 8502 0081000 1,000 FT 5.000 LB GRAY 8502 009100 100 FT 0.500 LB WHITE 8502 0091000 1,000 FT 5.000 LB WHITE 8502 010100 100 FT 0.500 LB BLACK 8502 0101000 1,000 FT 5.000 LB BLACK P 20 STR PVC BLK 8502 0151000 1,000 FT 5.000 LB WHITE/RED A 20 STR PVC WHT/RED 8502 0181000 1,000 FT 5.000 LB WHITE/BLUE A 20 STR PVC WHT/BLU 20 STR PVC BRN P 20 STR PVC BRN 20 STR PVC RED P 20 STR PVC RED 20 STR PVC ORG P 20 STR PVC ORG 20 STR PVC YEL P 20 STR PVC YEL 20 STR PVC GRN P 20 STR PVC GRN 20 STR PVC LBLU P 20 STR PVC LT.BLU 20 STR PVC VIO P 20 STR PVC VIO 20 STR PVC GRY P 20 STR PVC GRY 20 STR PVC WHT P 20 STR PVC WHT 20 STR PVC BLK Notes: A = STOCKED STRIPE COLORS. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 2 Revision Date: 11-07-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8502 0101000 价格&库存
很抱歉,暂时无法提供与“8502 0101000”相匹配的价格&库存,您可以联系我们找货
  • 305+8.52006305+1.10740
  • 610+7.47679610+0.97180
