Part Number: 8723
Audio, Control & Instrument, #22-2pr, PO, Indiv. Foil, PVC Jkt, CM
Product Description
Audio, Control & Instrument Cable, 22 AWG stranded (7x30) tinned copper conductors, polypropylene insulation, twisted pairs, individually Beldfoil® shielded
(100% coverage), 24 AWG stranded tinned copper drain wire, PVC jacket.
Technical Specifications
Physical Characteristics (Overall)
Conductor
AWG Stranding
22
7x30
Material
No. of Pairs
TC - Tinned Copper 2
Conductor Count:
4
Conductor Size:
22 AWG
Insulation
Material
Nominal Wall Thickness
PP - Polypropylene 0.009 in
Color Chart
Number
Color
1
Red & Black
2
Green & White
Inner Shield Material
Type
Material
Material Trade Name
Coverage [%] Drainwire Material
Tape Aluminum Foil-Polyester Tape Beldfoil® (Z-Fold®-foil side out) 100 %
Drainwire AWG Drainwire Construction n x D
TC - Tinned Copper 24
Outer Shield Material
Material
Unshielded
Outer Jacket Material
Material
Nominal Diameter Nominal Wall Thickness
PVC - Polyvinyl Chloride 0.16 in
0.02 in
Electrical Characteristics
Conductor DCR
Individual Pair Nominal Shield DCR Nominal Conductor DCR
15 Ohm/1000ft
14.7 Ohm/1000ft
Capacitance
Nom. Capacitance Conductor to Conductor Nom. Capacitance Conductor to Other Conductor to Shield
33 pF/ft
Inductance
Nominal Inductance
0.17 µH/ft
62 pF/ft
7x32
Impedance
Nominal Characteristic Impedance
52 Ohm
High Frequency (Nominal/Typical)
Nom. Insertion Loss
10 dB/100m
Delay
Nominal Velocity of Propagation (VP) [%]
66 %
Current
Max. Recommended Current [A]
Per conductor @ 25°C (10C temperature rise): 2.3 A
Voltage
UL Voltage Rating
300 V RMS
Temperature Range
UL Temp Rating:
60°C
Operating Temp Range:
-20°C To +75°C
Mechanical Characteristics
Bulk Cable Weight:
17 lbs/1000ft
Max Recommended Pulling Tension:
42 lbs
Min Bend Radius/Minor Axis:
1.75 in
Standards
NEC Articles:
800
NEC/(UL) Specification:
CM
CEC/C(UL) Specification:
CM
CPR Euroclass:
Eca
Applicable Environmental and Other Programs
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2003/96/EC (BFR):
Yes
EU Directive 2011/65/EU (ROHS II):
Yes
EU Directive 2012/19/EU (WEEE):
Yes
EU Directive 2015/863/EU:
Yes
EU Directive Compliance:
EU Directive 2003/11/EC (BFR)
EU CE Mark:
Yes
EU RoHS Compliance Date (yyyy-mm-dd): 2004-01-01
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Suitability
Suitability - Indoor:
Yes
Suitability - Outdoor:
No
Flammability, LS0H, Toxicity Testing
UL Flammability:
UL1685 (UL Loading)
ISO/IEC Flammability:
IEC 60332-1-2
UL voltage rating:
300 V RMS
Plenum/Non-Plenum
Plenum (Y/N):
No
Plenum Number:
82723, 87723, 88723
Part Number
Variants
Item #
Color
Footnote
8723.001000
Chrome
8723.0030
Chrome
8723.00U152
Chrome
8723.00U305
Chrome
8723.01152
Chrome
8723.011524
Chrome
8723.013048
Chrome
8723.01305
Chrome
8723.013050
Chrome
8723.01610
Chrome
8723.02500
Chrome
8723 060100
Chrome
8723 0601000
Chrome C
8723 06010000
Chrome C Y
8723 06010001
Chrome C
8723 06015000
Chrome
8723 0601640
Chrome
8723 0602000
Chrome C
8723 0603280
Chrome C
8723 060500
Chrome
8723 0605000
Chrome C
8723 0609999
Chrome C Y
8723 060U1000 Chrome
8723 060U2000 Chrome
8723 060U500
Chrome
Footnote:
C - CRATE REEL PUT-UP.
Footnote:
Y - FINAL PUT-UP LENGTH MAY VAR -10% TO +20% FROM LENGTH SHOWN. MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'.
© 2019 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without
notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages
(including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract,
negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief
at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product
Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and
regulations based on their individual usage of the product.
很抱歉,暂时无法提供与“8723 0602000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+13.969692000+1.81256
