8728 060500
8728 060500
    BELDEN
    2 #22 SHPR PP PVC
8728 060500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8728 Multi-Conductor - Special Audio, Communication and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, polypropylene insulation, cabled in pairs, overall Beldfoil® shield (100% coverage), 24 AWG stranded TC drain wires, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 2 22 7x30 TC - Tinned Copper .030 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Dia. (in.) PP - Polypropylene 0.050 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material Coverage (%) Layer 1 Beldfoil® Tape Aluminum Foil-Polyester Tape 100 Layer 2 Tape Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: Stranded Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .028 Overall Cable Overall Nominal Diameter: 0.215 in. Pair Pair Color Code Chart: Number Color 1 Black & Red 2 White & Green Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C UL Temperature Rating: 80°C (UL AWM Style 2717) Bulk Cable Weight: 28 lbs/1000 ft. Max. Recommended Pulling Tension: 36.400 lbs. Min. Bend Radius/Minor Axis: 2.250 in. Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8728 Multi-Conductor - Special Audio, Communication and Instrumentation Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2717 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 35 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 62 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 17 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 16.600 Ohm/1000 ft Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2717) Max. Recommended Current: Current 2.3 Amps per conductor @ 25°C Notes (Overall) Notes: Each pair Beldfoil® shielded with individual drain wire plus a polyester film over each shield. Put Ups and Colors: Item # Putup Ship Weight Color 8728 060U1000 1,000 FT 30.000 LB CHROME 8728 060U500 500 FT 15.500 LB CHROME 8728 0601000 1,000 FT 31.000 LB CHROME C 2 #22 SHPR PP PVC 8728 060500 500 FT 15.500 LB CHROME C 2 #22 SHPR PP PVC 8728 0605000 5,000 FT 145.000 LB CHROME C 2 #22 SHPR PP PVC Page 2 of 3 Notes Item Desc 2 #22 SHPR PP PVC 2 #22 SHPR PP PVC 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8728 Multi-Conductor - Special Audio, Communication and Instrumentation Cable Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 09-20-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
8728 060500
1. 物料型号:型号为LM324,是一款四运算放大器集成电路。 2. 器件简介:LM324是一种通用的、高增益、直接耦合的放大器,具有内部频率补偿功能,适用于多种应用。 3. 引脚分配:引脚1为非反相输入,引脚2为正相输入,引脚3为输出,引脚4为负电源,引脚5为反相输入,引脚6为正电源,引脚7和14为地,引脚8为输出,引脚11为输出,引脚12为输出。 4. 参数特性:包括电源电压范围(±3V至±32V)、静态功耗(1mA)、输入偏置电流(1pA)、增益带宽积(1MHz)等。 5. 功能详解:LM324可以用于多种模拟信号处理应用,如放大、滤波、信号整形等。 6. 应用信息:适用于音频放大、传感器信号调理、医疗仪器等。 7. 封装信息:提供多种封装形式,如SOIC、DIP等。
8728 060500 价格&库存
很抱歉,暂时无法提供与“8728 060500”相匹配的价格&库存,您可以联系我们找货
  • 152+47.37757152+6.14720
  • 304+42.15210304+5.46920
