88723 0025000
88723 0025000
    BELDEN
    CBL 2PR 22AWG SHLD
88723 0025000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 88723 Multi-Conductor - Shielded Twisted Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) tinned copper conductors, FEP insulation, twisted pairs, individually Beldfoil® shielded (100% coverage), 24 AWG stranded (7x32) tinned copper drain wire, FEP jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 2 22 7x30 TC - Tinned Copper Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene 0.007 Inner Shield Inner Shield Material: Inner Shield Trade Name Type Inner Shield Material Beldfoil® (Z-Fold®) Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: 7x32 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene 0.014 Overall Cable Overall Nominal Diameter: 0.148 in. Pair Pair Color Code Chart: Number Color 1 Red & Black 2 Green & White Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 19 lbs/1000 ft. Max. Recommended Pulling Tension: 46 lbs. Min. Bend Radius/Minor Axis: 1.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 88723 Multi-Conductor - Shielded Twisted Pair Cable EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: NFPA 262 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 8723 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 40 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 35 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 67 Nominal Velocity of Propagation: VP (%) 69 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.7 Nom. Inner Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.3 Amps per conductor @ 25°C Notes (Overall) Notes: Non.conduit. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 88723 002100 100 FT 3.400 LB RED C 2 SH PR #22 FEP FEP 88723 0021000 1,000 FT 21.000 LB RED C 2 SH PR #22 FEP FEP 88723 002500 500 FT 11.000 LB RED C 2 SH PR #22 FEP FEP 88723 0025000 5,000 FT 100.000 LB RED 2 SH PR #22 FEP FEP Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 08-15-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 88723 Multi-Conductor - Shielded Twisted Pair Cable All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
88723 0025000 价格&库存
很抱歉,暂时无法提供与“88723 0025000”相匹配的价格&库存,您可以联系我们找货
