Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
9269 Coax - 93 Ohms
For more Information
please call
1-800-Belden1
General Description:
22 AWG solid .025" bare copper-covered steel conductor, semi-solid polyethylene insulation, bare copper
braid shield (95% coverage), PVC jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
22
Solid
Dia. (in.)
BCCS - Bare Copper Covered Steel .025
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.) Dia. (in.)
Semi-Solid PE - Semi-Solid Polyethylene 0.026
0.146
Outer Shield
Outer Shield Material:
Type Outer Shield Material Coverage (%)
Braid BC - Bare Copper
95
Outer Jacket
Outer Jacket Material:
Nom. Wall Thickness (in.)
PVC - Polyvinyl Chloride 0.032
Overall Cable
Overall Nominal Diameter:
0.239 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-40°C To +80°C
UL Temperature Rating:
60°C (UL AWM Style 1478)
Bulk Cable Weight:
36 lbs/1000 ft.
Max. Recommended Pulling Tension:
84 lbs.
Min. Bend Radius/Minor Axis:
2.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CL2, CM
CEC/C(UL) Specification:
CM
AWM Specification:
UL Style 1478 (30 V 60°C)
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
PMSHA Specification:
SC-182/3
Customer Part Number Reference Specification:
IBM P/N 323921
Page 1 of 3
01-05-2017
9269 Coax - 93 Ohms
IBM P/N 323921
RG Type:
62A/U
Flame Test
UL Flame Test:
UL1685 UL Loading
Plenum/Non-Plenum
Plenum (Y/N):
No
Plenum Number:
89269, 87269, 82269
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
93
Nom. Inductance:
Inductance (µH/ft)
0.116
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
13.5
Nominal Velocity of Propagation:
VP (%)
84
Nominal Delay:
Delay (ns/ft)
1.21
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
41.2
Nominal Outer Shield DC Resistance:
2.9
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
0.3
10
0.9
50
1.9
100
2.7
200
3.8
400
5.3
700
7.3
900
8.2
1000
8.7
Max. Operating Voltage - UL:
Voltage
Description
300 V RMS CM
150 V RMS CL2
30 V RMS
AWM Style 1478
Max. Operating Voltage - Non-UL:
Voltage
750 V RMS
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
9269 A8RU1000
1,000 FT
36.000 LB
BEIGE, SNOW
Notes
Item Desc
RG-62A/U TYPE COAX
9269 003U1000
1,000 FT
36.000 LB
ORANGE
RG-62A/U TYPE COAX
9269 010U1000
1,000 FT
36.000 LB
BLACK
RG-62A/U TYPE COAX
9269 010U500
500 FT
18.500 LB
BLACK
RG-62A/U TYPE COAX 306 2.09
9269 0101000
1,000 FT
38.000 LB
BLACK
9269 0101640
1,640 FT
60.680 LB
BLACK
C
RG-62A/U TYPE COAX
9269 0102000
2,000 FT
76.000 LB
BLACK
C
RG-62A/U TYPE COAX
9269 0103280
3,280 FT
121.360 LB
BLACK
C
RG-62A/U TYPE COAX
9269 010500
500 FT
19.000 LB
BLACK
C
RG-62A/U TYPE COAX
9269 0105000
5,000 FT
185.000 LB
BLACK
C
RG-62A/U TYPE COAX
RG-62A/U TYPE COAX
Page 2 of 3
01-05-2017
9269 Coax - 93 Ohms
9269 060U1000
1,000 FT
36.000 LB
CHROME
RG-62A/U TYPE COAX
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 08-16-2012
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“9269 0101000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+46.727711+6.05680
- 50+37.0508950+4.80250
- 100+33.12785100+4.29400
- 305+29.20482305+3.78550
