9451 N3UU1000
9451 N3UU1000
    BELDEN
    2 #22 PP FS PVC FR 1=1000'
9451 N3UU1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9451 Multi-Conductor - Single-Pair Cables For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, polypropylene insulation, twisted pair, overall Beldfoil shield (100% coverage), 22 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 22 7x30 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PP - Polypropylene .008 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 7x30 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .020 Overall Cable Overall Nominal Diameter: 0.135 in. Pair Pair Color Code Chart: Number Color 1 Black & Red Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +75°C UL Temperature Rating: 60°C Bulk Cable Weight: 14 lbs/1000 ft. Max. Recommended Pulling Tension: 27 lbs. Min. Bend Radius/Minor Axis: 1.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9451 Multi-Conductor - Single-Pair Cables EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1666 Vertical Shaft CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 45 Nom. Inductance: Inductance (µH/ft) .17 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 35 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 67 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/ft) 1.5 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.1 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 14.3 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 2.9 Amps per conductor @ 25°C Notes (Overall) Notes: The jacket and shield are bonded so both can be removed on automatic stripping equipment. Drain wire is inside foil shield. For cross-connect use with 1814R (et. al.) Snake Cables. Put Ups and Colors: Item # Putup Ship Weight Color 9451 N3UU1000 1,000 FT 16.000 LB GREEN, MIL 9451 N3U5000 5,000 FT 70.000 LB GREEN, MIL 9451 001U1000 1,000 FT 16.000 LB BROWN 9451 0015000 5,000 FT 70.000 LB BROWN 9451 002N1000 1,000 FT 18.000 LB RED 9451 002U1000 1,000 FT 16.000 LB RED 9451 0025000 5,000 FT 75.000 LB RED 9451 003U1000 1,000 FT 16.000 LB ORANGE 9451 0035000 5,000 FT 75.000 LB ORANGE 9451 004N1000 1,000 FT 18.000 LB YELLOW 9451 004U1000 1,000 FT 16.000 LB YELLOW 9451 0045000 5,000 FT 75.000 LB YELLOW 9451 006U1000 1,000 FT 16.000 LB BLUE, LIGHT 9451 0065000 5,000 FT 75.000 LB BLUE, LIGHT Page 2 of 3 Notes Item Desc 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PO FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9451 Multi-Conductor - Single-Pair Cables 9451 007U1000 1,000 FT 16.000 LB VIOLET 9451 0075000 5,000 FT 75.000 LB VIOLET 2 #22 PP FS PVC FR 9451 008N1000 1,000 FT 18.000 LB GRAY 2 #22 PP FS PVC FR 9451 008T1000 1,000 FT 16.000 LB GRAY 2 #22 PP FS PVC FR 9451 008U1000 1,000 FT 16.000 LB GRAY 2 #22 PP FS PVC FR 9451 008U500 500 FT 8.500 LB GRAY 2 #22 PP FS PVC FR 9451 008500 500 FT 8.000 LB GRAY 9451 0085000 5,000 FT 75.000 LB GRAY 9451 009U1000 1,000 FT 16.000 LB WHITE 9451 0095000 5,000 FT 75.000 LB WHITE 9451 010N1000 1,000 FT 18.000 LB BLACK 2 #22 PP FS PVC FR 9451 010U1000 1,000 FT 16.000 LB BLACK 2 #22 PP FS PVC FR 9451 0101000 1,000 FT 16.000 LB BLACK 9451 0105000 5,000 FT 75.000 LB BLACK CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR 2 #22 PP FS PVC FR CN 2 #22 PP FS PVC FR Notes: C = CRATE REEL PUT-UP. N = FINAL PUT-UP LENGTH MAY VARY -0% TO +10% FROM LENGTH SHOWN. Revision Number: 1 Revision Date: 08-08-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9451 N3UU1000 价格&库存
很抱歉,暂时无法提供与“9451 N3UU1000”相匹配的价格&库存,您可以联系我们找货
9451 N3UU1000
  • 1000+4.687941000+0.60646
