9913 010500
9913 010500
    BELDEN
    RG-8/U TYPE COAX
9913 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9913 Coax - RG-8/U Type For more Information please call 1-800-Belden1 General Description: 10 AWG solid .108" bare copper conductor, semi-solid polyethylene insulation, Duobond II® + tinned copper braid shield (90% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 10 Solid BC - Bare Copper .108 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Semi-Solid PE - Semi-Solid Polyethylene .286 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded DuoFoil® 2 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 90 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.405 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Non-UL Temperature Rating: 75°C Bulk Cable Weight: 107 lbs/1000 ft. Max. Recommended Pulling Tension: 300 lbs. Min. Bend Radius/Minor Axis: 4 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 8/U Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 89913 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9913 Coax - RG-8/U Type Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 50 Nom. Inductance: Inductance (µH/ft) .059 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 24.6 Nominal Velocity of Propagation: VP (%) 84 Nominal Delay: Delay (ns/ft) 1.2 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) .9 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 1.8 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 5.000 0.400 10.000 0.500 50.000 1.000 100.000 1.400 200.000 1.800 400.000 2.600 700.000 3.600 900.000 4.100 1000.000 4.400 Max. Power Rating: Freq. (MHz) Rating (W) 5.000 4021.000 10.000 3217.000 50.000 1609.000 100.000 1149.000 200.000 894.000 400.000 619.000 700.000 447.000 900.000 393.000 1000.000 366.000 Max. Operating Voltage - Non-UL: Voltage 600 V RMS Notes (Overall) Notes: Recommend use of 7810R, 7810A, 9913F7, or 9914 for applications above 1 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9913 010100 100 FT 14.200 LB BLACK C RG-8/U TYPE COAX 9913 0101000 1,000 FT 116.000 LB BLACK C RG-8/U TYPE COAX 9913 010250 250 FT 31.750 LB BLACK C RG-8/U TYPE COAX 9913 010500 500 FT 57.000 LB BLACK C RG-8/U TYPE COAX 9913 0105000 5,000 FT 625.000 LB BLACK C RG-8/U TYPE COAX Notes: C = CRATE REEL PUT-UP. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9913 Coax - RG-8/U Type Revision Number: 2 Revision Date: 07-29-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
9913 010500 价格&库存
很抱歉,暂时无法提供与“9913 010500”相匹配的价格&库存,您可以联系我们找货
  • 1+14508.609321+1876.91010
  • 2+12867.444682+1664.60040
