9916 0025000
9916 0025000
    BELDEN
    HOOK-UP 16AWG STR RED
9916 0025000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9916 Hook-up/Lead - UL AWM Style 1007 and 1569 For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, PVC insulation. Rated 105ºC, 300V. Rated 600V peak for electronic circuits, and internal wiring for electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 16 26x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (mm) Min. Avg. Wall (mm) PVC - Polyvinyl Chloride 0.406 0.381 Overall Insulation Overall Cable Overall Nominal Diameter: 2.337 mm Mechanical Characteristics (Overall) Bulk Cable Weight: 17.114 Kg/Km Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 1007 (300 V 80°C), UL Style 1569 (300 V 105°C) UL Rating: 300 V RMS, 80°C and 300 V, 105°C CSA Rating: 300 V RMS, 105°C CSA Type: TRSR-64 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Plenum/Non-Plenum Page 1 of 2 10-14-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9916 Hook-up/Lead - UL AWM Style 1007 and 1569 Plenum (Y/N): No Put Ups and Colors: Item # Putup Ship Weight Color 9916 001100 30 MT 0.590 KG BROWN Notes Item Desc 9916 0011000 305 MT 5.443 KG BROWN 9916 002100 30 MT 0.590 KG RED 9916 0021000 305 MT 5.443 KG RED P 16 STR PVC RED 9916 0025000 1,524 MT 27.216 KG RED P #16 STR PVC RED 9916 0031000 305 MT 5.443 KG ORANGE P 16 STR PVC ORG 9916 004100 30 MT 0.590 KG YELLOW 9916 0041000 305 MT 5.443 KG YELLOW 9916 005100 30 MT 0.590 KG GREEN, DARK 9916 0051000 305 MT 5.443 KG GREEN, DARK 9916 007100 30 MT 0.590 KG VIOLET 9916 0071000 305 MT 5.443 KG VIOLET P 16 STR PVC VIO 9916 0081000 305 MT 5.443 KG GRAY P 16 STR PVC GRY 9916 009100 30 MT 0.590 KG WHITE 9916 0091000 305 MT 5.443 KG WHITE P 16 STR PVC WHT 9916 0095000 1,524 MT 27.216 KG WHITE P #16 STR PVC WHT 9916 010100 30 MT 0.590 KG BLACK 9916 0101000 305 MT 5.443 KG BLACK P 16 STR PVC BLK 9916 0105000 1,524 MT 27.216 KG BLACK P #16 STR PVC BLK 9916 013100 30 MT 0.590 KG BLUE, DARK 9916 0131000 305 MT 5.443 KG BLUE, DARK 16 STR PVC BRN P 16 STR PVC BRN 16 STR PVC RED 16 STR PVC YEL P 16 STR PVC YEL 16 STR PVC D GRN P 16 STR PVC D GRN 16 STR PVC VIO 16 STR PVC WHT 16 STR PVC BLK 16 STR PVC D BLU P 16 STR PVC DBLU Notes: P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 4 Revision Date: 03-01-2010 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 2 of 2 10-14-2013
9916 0025000 价格&库存
很抱歉,暂时无法提供与“9916 0025000”相匹配的价格&库存,您可以联系我们找货
