9921 0085000
9921 0085000
    BELDEN
    HOOK-UP 22AWG STR GRY
9921 0085000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9921 Hook-up/Lead - UL AWM Style 1007 and 1569 For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, PVC insulation. Rated 105ºC, 300V. Rated 600V peak for electronic circuits, and internal wiring of electronic and electrical equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 22 7x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (mm) Min. Avg. Wall (mm) PVC - Polyvinyl Chloride 0.419 0.381 Overall Insulation Overall Cable Overall Nominal Diameter: 1.575 mm Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +105°C Bulk Cable Weight: 5.209 Kg/Km Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL AWM Style: UL Style 1007 (300 V 80°C), UL Style 1569 (300 V 105°C) UL Rating: 300 V RMS, 80°C and 300 V, 105°C CSA Rating: 300 V RMS, 105°C CSA Type: TRSR-64 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 CSA Flame Test: FT1 Page 1 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9921 Hook-up/Lead - UL AWM Style 1007 and 1569 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 50.035 Max. Operating Voltage - UL: Voltage 300 VRMS Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient. 11 amps Put Ups and Colors: Item # Putup Ship Weight Color 9921 001100 30 MT 0.181 KG BROWN Notes Item Desc 9921 0011000 305 MT 1.814 KG BROWN 9921 002100 30 MT 0.181 KG RED 9921 0021000 305 MT 1.814 KG RED P 22 STR PVC RED 9921 0025000 1,524 MT 9.072 KG RED CP #22 STR PVC RED 9921 003100 30 MT 0.181 KG ORANGE 9921 0031000 305 MT 1.814 KG ORANGE 9921 004100 30 MT 0.181 KG YELLOW 9921 0041000 305 MT 1.814 KG YELLOW P 22 STR PVC YEL 9921 0045000 1,524 MT 9.072 KG YELLOW C #22 STR PVC YEL 9921 005100 30 MT 0.181 KG GREEN, DARK 9921 0051000 305 MT 1.814 KG GREEN, DARK 9921 006100 30 MT 0.181 KG BLUE, LIGHT 9921 0061000 305 MT 1.814 KG BLUE, LIGHT 9921 007100 30 MT 0.181 KG VIOLET 9921 0071000 305 MT 1.814 KG VIOLET 9921 008100 30 MT 0.181 KG GRAY 9921 0081000 305 MT 1.814 KG GRAY P 22 STR PVC GRY 9921 0085000 1,524 MT 9.072 KG GRAY CP #22 STR PVC GRY 9921 009100 30 MT 0.181 KG WHITE 9921 0091000 305 MT 1.814 KG WHITE 9921 010100 30 MT 0.181 KG BLACK 9921 0101000 305 MT 1.814 KG BLACK P 22 STR PVC BLK 9921 0105000 1,524 MT 9.072 KG BLACK C #22 STR PVC BLK 9921 013100 30 MT 0.181 KG BLUE, DARK 9921 0131000 305 MT 1.814 KG BLUE, DARK P 22 STR PVC D BLU 9921 0135000 1,524 MT 9.072 KG BLUE, DARK C #22 STR PVC DBLU 22 STR PVC BRN P 22 STR PVC BRN 22 STR PVC RED 22 STR PVC ORG P 22 STR PVC ORG 22 STR PVC YEL 22 STR PVC D GRN P 22 STR PVC D GRN 22 STR PVC LBLU P 22 STR PVC LBLU 22 STR PVC VIO P 22 STR PVC VIO 22 STR PVC GRY 22 STR PVC WHT P 22 STR PVC WHT 22 STR PVC BLK 22 STR PVC D BLU Notes: C = CRATE REEL PUT-UP. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 4 Revision Date: 04-23-2013 © 2013 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. Page 2 of 3 10-30-2013 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 9921 Hook-up/Lead - UL AWM Style 1007 and 1569 All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 73/23/EEC), as amended by directive 93/68/EEC. Page 3 of 3 10-30-2013
9921 0085000 价格&库存
很抱歉,暂时无法提供与“9921 0085000”相匹配的价格&库存,您可以联系我们找货
