AX100116
AX100116
    BELDEN
    FEXPRESS, RACK MOUNT PATCH
AX100116 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX100116 Faceplates and Panels - FiberExpress Rack Mount Patch Panel 4U For more Information please call 1-800-Belden1 General Description: FiberExpress Patch Panel, Rack Mount, 4U, Black. Usage (Overall) Suitable Applications: FiberExpress Solutions, Backbone, Telecommunications Room, Main Distribution Room Related Parts: FiberExpress Adapter Strips, Fiber Splice Organizer Trays and Kits Physical Characteristics (Connectivity) Capacity Max. Capacity: 8 Strips;96 Fibers (SC, SCD, ST, FC);192 Fibers (LCD, MT-RJ);Four 8-inch Splice Tray kit (A0649869);Four 12-inch Splice Tray Kit (A0318904) Access Front Connection: Flush Termination Area: Front Sliding Drawer Dimensions Dimensions: Height (in.) Width (in.) Depth (in.) 6.900 19.000 12.000 Materials Materials: Description Material Panel Steel Cover Lexan Color Color: Black Weight Weight: 26 lbs. Included Parts Included Parts: 4 Screws (10x32); 30 Tie Wraps; Identification Label; Caution Label; Admin Label Packaging Packaging: Individually packaged in a cardboard box. Mechanical Characteristics (Connectivity) Storage Temperature Range: -40°C To +70°C Operating Temperature Range: -10°C To +60°C Applicable Specifications and Agency Compliance (Overall) Suitability Suitability - Indoor: Yes Notes (Overall) Notes: For proper installation refer to Installation Guide PX100125 included with the product or visit our web site at http://www.belden.com Product Family Part Numbers: Description Item Number FiberExpress Rack Mount PP 1U Black AX100041 FiberExpress Rack Mount PP 2U Black AX100068 FiberExpress Rack Mount PP 3U Black AX104934 FiberExpress Rack Mount PP 4U Black AX100116 Put Ups and Colors: Item # Putup Ship Weight AX100116 1 EA 10.500 KG Color Notes Item Desc F'EXPRESS, RACK MOUNT PATCH Page 1 of 2 03-13-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION AX100116 Faceplates and Panels - FiberExpress Rack Mount Patch Panel 4U Revision Number: 0 Revision Date: 05-31-2009 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 03-13-2017
AX100116
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种高速光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817有6个引脚,分别为1脚发射极,2脚集电极,3脚GND,4脚VCC,5脚输出,6脚输入。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号隔离,常用于数字信号传输。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP-6封装。
AX100116 价格&库存
很抱歉,暂时无法提供与“AX100116”相匹配的价格&库存,您可以联系我们找货
