C6F1102085
C6F1102085
    BELDEN
    PATCHCORD CAT6F CMR RED 85FT
C6F1102085 数据手册
Product: CAT6+ F/UTP CMR PATCH CORDS CAT6+ F/UTP CMR Patch Cords Product Description CAT6+ F/UTP CMR Patch Cords Technical Specifications Product Overview Suitable Applications: IBDN Shielded System 2400, TIA Category 6, ISO Class E, 1000BASE-T Physical Characteristics (Overall) Total Number of Pairs: 4 Overall Nominal Diameter: 0.26 in Wiring Scheme: T568A/B-T568A/B Packaging: Individually packaged in a clear plastic bag. Connectors Materials Materials Color Description Same as cable Boot Conductor Material Elastomer BC - Bare Copper Front Connection Blades Phosphor Bronze with 50u inch Gold over Nickel Plating Inner Jacket PVC - Polyvinyl Chloride PO - Polyolefin Inner Jacket PVC - Polyvinyl Chloride PVC - Polyvinyl Chloride Inner Jacket PVC - Polyvinyl Chloride Electrical Characteristics Dielectric Strength: 1,000 V RMS @ 60 Hz for 1 minute Current Rating: 1.500 A Insulation Resistance: 500 M-Ohm Minimum Max Contact Resistance: 20 mOhm Temperature Range Installation Temp Range: -10°C To +60°C Storage Temp Range: -40°C To +70°C Operating Temp Range: -10°C To +60°C Mechanical Characteristics Min Bend Radius (Overall Cable): 2.080 in Plug /Jack Compatibility: RJ45 Termination Interface Connection Durabilities Mated Connection 750 Cycles Standards UL Rating: Riser Data Category: Category 6+ TIA/EIA Compliance: Category 6 - TIA 568-C.2, Class E - ISO/IEC 11801:2002 Ed.2 Amendment 2 Other Compliance: FCC Part 68, Subpart F, IEC 60603-7 Applicable Environmental and Other Programs Environmental Space: Riser EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (yyyy-mm-dd): 2006-01-01 MII Order #39 (China RoHS): EUP 50 Flammability, LS0H, Toxicity Testing Safety Listing: c(UL)us Listed Part Number Related Parts: CAT6+ Shielded KeyConnect Modular Jacks and Couplers, Shielded Patch Panels Variants Item # Color Length C6F1100001 Black 1 ft C6F1100002 Black 2 ft C6F1100003 Black 3 ft C6F1100004 Black 4 ft C6F1100005 Black 5 ft C6F1100006 Black 6 ft C6F1100007 Black 7 ft C6F1100008 Black 8 ft C6F1100009 Black 9 ft C6F1100010 Black 10 ft C6F1100011 Black 11 ft C6F1100012 Black 12 ft C6F1100013 Black 13 ft C6F1100014 Black 14 ft C6F1100015 Black 15 ft C6F1100020 Black 20 ft C6F1100025 Black 25 ft C6F1100050 Black 50 ft C6F1100082 Black 82 ft C6F1106001 Blue 1 ft C6F1106002 Blue 2 ft C6F1106003 Blue 3 ft C6F1106004 Blue 4 ft C6F1106005 Blue 5 ft C6F1106006 Blue 6 ft C6F1106007 Blue 7 ft C6F1106008 Blue 8 ft C6F1106009 Blue 9 ft C6F1106010 Blue 10 ft C6F1106011 Blue 11 ft C6F1106012 Blue 12 ft C6F1106013 Blue 13 ft C6F1106014 Blue 14 ft C6F1106015 Blue 15 ft C6F1106017 Blue 17 ft C6F1106020 Blue 20 ft C6F1106025 Blue 25 ft C6F1106035 Blue 35 ft C6F1106050 Blue 50 ft C6F1106060 Blue 60 ft C6F1106066 Blue 66 ft C6F1106075 Blue 75 ft C6F1106082 Blue 82 ft C6F1106090 Blue 90 ft C6F1108001 Gray 1 ft C6F1108002 Gray 2 ft C6F1108003 Gray 3 ft C6F1108004 Gray 4 ft C6F1108005 Gray 5 ft C6F1108006 Gray 6 ft C6F1108007 Gray 7 ft C6F1108008 Gray 8 ft C6F1108009 Gray 9 ft C6F1108010 Gray 10 ft C6F1108011 Gray 11 ft C6F1108012 Gray 12 ft C6F1108013 Gray 13 ft C6F1108014 Gray 14 ft C6F1108015 Gray 15 ft C6F1108020 Gray 20 ft C6F1108025 Gray 25 ft C6F1108030 Gray 30 ft C6F1108035 Gray 35 ft C6F1108050 Gray 50 ft C6F1108080 Gray 80 ft C6F1108100 Gray 100 ft C6F1108115 Gray 115 ft C6F1108130 Gray 130 ft C6F1105005 Green 5 ft C6F1105009 Green 9 ft C6F1105010 Green 10 ft C6F1105015 Green 15 ft C6F1105023 Green 23 ft C6F1102002 Red 2 ft C6F1102003 Red 3 ft C6F1102004 Red 4 ft C6F1102005 Red 5 ft C6F1102006 Red 6 ft C6F1102007 Red 7 ft C6F1102008 Red 8 ft C6F1102009 Red 9 ft C6F1102010 Red 10 ft C6F1102015 Red 15 ft C6F1102020 Red 20 ft C6F1102025 Red 25 ft C6F1102030 Red 30 ft C6F1102035 Red 35 ft C6F1102050 Red 50 ft C6F1102075 Red 75 ft C6F1102080 Red 80 ft C6F1102085 Red 85 ft C6F1102090 Red 90 ft C6F1102100 Red 100 ft C6F1102200 Red 200 ft C6F1109001 White 1 ft C6F1109002 White 2 ft C6F1109003 White 3 ft C6F1109004 White 4 ft C6F1109005 White 5 ft C6F1109006 White 6 ft C6F1109007 White 7 ft C6F1109008 White 8 ft C6F1109009 White 9 ft C6F1109010 White 10 ft C6F1109011 White 11 ft C6F1109012 White 12 ft C6F1109013 White 13 ft C6F1109014 White 14 ft C6F1109015 White 15 ft C6F1109020 White 20 ft C6F1109025 White 25 ft C6F1109035 White 35 ft C6F1109050 White 50 ft Product Notes Labeling: Belden Part Number, Performance Acronym, Wiring Scheme and Cord Length. History Update and Revision: Revision Number: 0.154 Revision Date: 01-31-2020 © 2020 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
C6F1102085 价格&库存
很抱歉,暂时无法提供与“C6F1102085”相匹配的价格&库存,您可以联系我们找货
