MachFlex 375 CY Cables
Shielded (CY) PVC Control Cables
Tinned Copper Braid Shield (TCB) Excellent Noise Immunity
Applications
Designed for applications which are installed in occasional flexing and fixed locations. Cable
applications include precision control sensors, multi axis control machines, temperature
controllers, control panels, machine cutting tools, auxiliary equipment, motor speed control,
production machinery and many more.
General Reference Standards
DIN VDE 0295, IEC 60228, BS6360
DIN EN 50290-2-22, DIN VDE 0207-363-4-1
IEC 60227-5, VDE 0281
DIN VDE 0482-332-1-2, DIN EN 60332-1-2, IEC 60332-1-2
RoHS & REACH Directives
Construction and Performance
1.
Conductor Material
Stranded bare copper (DIN VDE 0295 Class 5)
2.
Insulation Material & Color
PVC (polyvinyl chloride). A) AA) Up to 5 cores: color-coded.
From 6 cores: Belden MachFlex Color code. B) G = with GN-YE protective
conductor; X = without protective conductor.
3.
Braid Shield Material
4.
Jacket / Sheath Material
5.
Flame Retardancy
6.
Voltage Rating (Uo/U)
Up to 1.5 mm2: 300 / 500 V
From 2.5 mm2: 450 / 750 V
7.
Oil Resistant
DIN EN 50290-2-22 (TM54)
8.
Temperature Range
-5 °C TO +70 °C (Occasional movement)
-40 °C TO +80 °C (Fixed installation)
9.
Bending Radius
20 x OD (Occasional movement)
6 x OD (Fixed installation)
10.
Other Properties
Good UV resistance, chemical resistance & flexibility
MachFlex 375 CY Shielded (CY) PVC Control Cables
TINNED COPPER BRAID SHIELDED CABLE WITH (G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.2
7.7
8.3
8.9
11.3
13.9
1 = Conductor
2 = Insulation
3 = Inner Sheath
4 = Tinned Copper Braid Shielded
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
45.08
53.90
64.68
78.40
135.73
226.25
EMEA
Part Code
C3GACY
C4GACY
C5GACY
C7GACY
C12GACY
C20GACY
APAC
Part Code
C3G0.5CY
C4G0.5CY
C5G0.5CY
C7G0.5CY
C12G0.5CY
C20G0.5CY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.7
8.3
9.0
9.7
12.4
15.2
Copper Weight
(kg/km)
55.86
62.72
75.46
99.96
173.46
289.10
EMEA
APAC
Part Code
Part Code
C3GBCY C3G0.75CY
C4GBCY C4G0.75CY
C5GBCY C5G0.75CY
C7GBCY
C7G0.75CY
C12GBCY C12G0.75CY
C20GBCY C20G0.75CY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.2
63.70
4
8.8
76.44
5
9.6
87.22
7
10.3
110.74
12
13.4
184.34
307.23
Conductor 2.50 mm2
EMEA
Part Code
C3GCCY
C4GCCY
C5GCCY
C7GCCY
C12GCCY
C20GCCY
APAC
Part Code
C3G1.0CY
C4G1.0CY
C5G1.0CY
C7G1.0CY
C12G1.0CY
C20G1.0CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.8
77.42
4
9.5
95.06
5
10.3
113.68
7
11.1
146.02
12
14.5
274.40
457.33
Conductor 4.00 mm2
EMEA
Part Code
C3GDCY
C4GDCY
C5GDCY
C7GDCY
C12GDCY
C20GDCY
APAC
Part Code
C3G1.5CY
C4G1.5CY
C5G1.5CY
C7G1.5CY
C12G1.5CY
C20G1.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.0
143.08
4
13.3
163.66
5
14.5
196.00
7
15.8
282.24
9
19.2
362.88
12
20.8
467.75
Conductor 6.00 mm2
EMEA
Part Code
C3GECY
C4GECY
C5GECY
C7GECY
C9GECY
C12GECY
APAC
Part Code
C3G2.5CY
C4G2.5CY
C5G2.5CY
C7G2.5CY
C9G2.5CY
C12G2.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
13.7
174.20
4
15.1
232.26
5
16.5
274.40
7
18.0
384.16
9
22.0
493.92
12
24.0
658.56
Conductor 10.00 mm2
EMEA
Part Code
C3GFCY
C4GFCY
C5GFCY
C7GFCY
C9GFCY
C12GFCY
APAC
Part Code
C3G4CY
C4G4CY
C5G4CY
C7G4CY
C9G4CY
C12G4CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3GGCY
C4GGCY
C5GGCY
C7GGCY
C9GGCY
APAC
Part Code
C3G6CY
C4G6CY
C5G6CY
C7G6CY
C9G6CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3GHCY
C4GHCY
C5GHCY
C7GHCY
C9GHCY
APAC
Part Code
C3G10CY
C4G10CY
C5G10CY
C7G10CY
C9G10CY
EMEA
Part Code
C3GJCY
C4GJCY
C5GJCY
APAC
Part Code
C3G25CY
C4G25CY
C5G25CY
Nom. Overall
Diameter (mm)
15.3
16.8
18.4
20.1
24.9
Copper Weight
(kg/km)
233.73
311.64
432.18
519.40
667.80
Conductor 16.00 mm2
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
22.5
24.9
27.4
Copper Weight
(kg/km)
594.86
787.92
916.30
Nom. Overall
Diameter (mm)
17.9
19.8
21.7
24.0
29.6
Copper Weight
(kg/km)
355.15
507.64
583.10
780.08
1,004.24
Conductor 25.00 mm2
EMEA
Part Code
C3GICY
C4GICY
C5GICY
APAC
Part Code
C3G16CY
C4G16CY
C5G16CY
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
25.4
28.1
30.8
• Putup length & tolerance of the cables will vary depending on the construction of the cable
• MOQ will vary depending on the construction of the cable & provided at the time of quotation
• Cable requested outside the above design criteria can be reviewed and quoted
Copper Weight
(kg/km)
853.33
1,137.78
1,372.00
TINNED COPPER BRAID SHIELDED CABLE WITHOUT (G) PROTECTIVE GROUND
5
4
3
2
1
Conductor 0.50 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.2
7.7
8.3
8.9
11.3
13.9
1 = Conductor
2 = Insulation
3 = Inner Sheath
5 = Outer Sheath
Conductor 0.75 mm2
Copper Weight
(kg/km)
45.08
53.90
64.68
78.40
135.73
226.25
EMEA
Part Code
C3XACY
C4XACY
C5XACY
C7XACY
C12XACY
C20XACY
APAC
Part Code
C3X0.5CY
C4X0.5CY
C5X0.5CY
C7X0.5CY
C12X0.5CY
C20X0.5CY
Conductor 1.00 mm2
No. of
Cores
3
4
5
7
12
Nom. Overall
Diameter (mm)
7.7
8.3
9.0
9.7
12.4
15.2
Copper Weight
(kg/km)
55.86
62.72
75.46
99.96
173.46
289.10
EMEA
Part Code
C3XBCY
C4XBCY
C5XBCY
C7XBCY
C12XBCY
C20XBCY
APAC
Part Code
C3X0.75CY
C4X0.75CY
C5X0.75CY
C7X0.75CY
C12X0.75CY
C20X0.75CY
Conductor 1.50 mm2
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.2
63.70
4
8.8
76.44
5
9.6
87.22
7
10.3
110.74
12
13.4
184.34
307.23
Conductor 2.50 mm2
EMEA
Part Code
C3XCCY
C4XCCY
C5XCCY
C7XCCY
C12XCCY
C20XCCY
APAC
Part Code
C3X1.0CY
C4X1.0CY
C5X1.0CY
C7X1.0CY
C12X1.0CY
C20X1.0CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
8.8
77.42
4
9.5
95.06
5
10.3
113.68
7
11.1
146.02
12
14.5
274.40
457.33
Conductor 4.00 mm2
EMEA
Part Code
C3XDCY
C4XDCY
C5XDCY
C7XDCY
C12XDCY
C20XDCY
APAC
Part Code
C3X1.5CY
C4X1.5CY
C5X1.5CY
C7X1.5CY
C12X1.5CY
C20X1.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
12.0
143.08
4
13.3
163.66
5
14.5
196.00
7
15.8
282.24
9
19.2
362.88
12
20.8
467.75
Conductor 6.00 mm2
EMEA
Part Code
C3XECY
C4XECY
C5XECY
C7XECY
C9XECY
C12XECY
APAC
Part Code
C3X2.5CY
C4X2.5CY
C5X2.5CY
C7X2.5CY
C9X2.5CY
C12X2.5CY
No. of Nom. Overall
Copper Weight
Cores Diameter (mm)
(kg/km)
3
13.7
174.20
4
15.1
232.26
5
16.5
274.40
7
18.0
384.16
9
22.0
493.92
12
24.0
658.56
Conductor 10.00 mm2
EMEA
Part Code
C3XFCY
C4XFCY
C5XFCY
C7XFCY
C9XFCY
C12XFCY
APAC
Part Code
C3X4CY
C4X4CY
C5X4CY
C7X4CY
C9X4CY
C12X4CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3XGCY
C4XGCY
C5XGCY
C7XGCY
C9XGCY
APAC
Part Code
C3X6CY
C4X6CY
C5X6CY
C7X6CY
C9X6CY
No. of
Cores
3
4
5
7
9
EMEA
Part Code
C3XHCY
C4XHCY
C5XHCY
C7XHCY
C9XHCY
APAC
Part Code
C3X10CY
C4X10CY
C5X10CY
C7X10CY
C9X10CY
EMEA
Part Code
C3XJCY
C4XJCY
C5XJCY
APAC
Part Code
C3X25CY
C4X25CY
C5X25CY
Nom. Overall
Diameter (mm)
15.3
16.8
18.4
20.1
24.9
Copper Weight
(kg/km)
233.73
311.64
432.18
519.40
667.80
Conductor 16.00 mm2
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
22.5
24.9
27.4
Copper Weight
(kg/km)
594.86
787.92
916.30
Nom. Overall
Diameter (mm)
17.9
19.8
21.7
24.0
29.6
Copper Weight
(kg/km)
355.15
507.64
583.10
780.08
1,004.24
Conductor 25.00 mm2
EMEA
Part Code
C3XICY
C4XICY
C5XICY
APAC
Part Code
C3X16CY
C4X16CY
C5X16CY
No. of
Cores
3
4
5
Nom. Overall
Diameter (mm)
25.4
28.1
30.8
Copper Weight
(kg/km)
853.33
1,137.78
1,372.00
很抱歉,暂时无法提供与“C7GDCY-KC50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+16.563935+2.14700
- 25+14.4716425+1.87580
