Product Bulletin
PB 504
Cable Pro®
Installation Tool
Standard compression tool
for Snap-N-Seal® Connectors,
including F Male, RCA, BNC
and Right Angle, Inline Splices
and Ground Blocks for Series
59 and 6 coaxial cables.
Allows you to feel the
compression, hear the
“snap” as the connector
is compressed and see
the O-ring disappear
inside the connector
Key Benefits:
Physical Properties:
• Provides consistent results on every
installation
• Body: Nickel-Plated Heat-Treated Metal
• Plier-type tool with riveted construction
• Tool Weight: 9.5 oz (269 g)
• Handle Grips: Plastisol
• When you release the handle lock, it activates
the built–in handle spring mechanism,
opening the tool jaws
• Support plate centers the connectors
• Support plate fingers provide 300° support
during connector compression
• Handle lock is provided to conveniently
store the tool when not in use
• Part Number is stamped on the tool
for easy identification
Part
Number
Description
SNSUTL
Compression Tool, Non Ratchet, Series RG59 and RG6, for F
Male, RCA, BNC, Right Angle Connectors, Inline Splices and
Ground Blocks
Belden Technical Support 1.800.BELDEN.1 : (1.800.235.3361)
©Copyright 2012, Belden Inc.
www.belden.com
Inner Pack
Outer Pack
1
50
PB 504
很抱歉,暂时无法提供与“CPSNSCT-596”相匹配的价格&库存,您可以联系我们找货
