FSNS59BNCU-25
FSNS59BNCU-25
    BELDEN
    PROSNS RG59 BNC UNIV. 25 PACK
FSNS59BNCU-25 数据手册
Product: FSNS59BNCU-25 ProSNS RG-59 Universal BNC Coax Compression Connector Product Description ProSNS RG59 Universal BNC compression connector, non-blind entry with split ferrule design, polymer compression sleeve for easy insertion & lowest possible tool compression force. Universal BNC connector for standard or quad-shield RG59 cable. 25 per Pack Technical Specifications Product Overview Suitable Applications: CCTV, Security Cameras, Video Physical Characteristics (Overall) Packaging: 25 Pack Number of Pieces: 1 Connectors Materials Description Material Nut Nickel/Tin Plated Brass O-Ring Ethylene Propylene Body Nickel/Tin Plated Brass Contact Gold Plated Electrical Characteristics Impedance Nominal Characteristic Impedance 75 Ohm Return Loss (RL) Frequency [MHz] ≥-32 dB up to 1 GHz typical Electrical Characteristics Notes: Salt Fog: Passes 1000 hours ANSI/SCTE 143 2007, RFI Shielding: -85 dB (60% bonded foil), All Belden ProSNS connectors meet or exceed SCTE return loss standards. Temperature Range Operating Temp Range: -40°F (-40°C) to 140°F (60°C) Mechanical Characteristics Footprint/Type: Coax Connector Interface Type: BNC Gender: Male - plug Connector Series Name: ProSNS Color Band: Red Locking: No Tool Compatibility: CPLCCT-SLMR or CPSNSCT-596 (compression), PSA59/6 (strip) Termination Type: Compression Cable Center Conductor Diameter Limits: .0317 - .0339 inch Cable Dielectric Diameter Limits: .144 - .157 inch Cable Outer Jacket Diameter Limits: .232 - .273 inch Cable Insertion Force: 20 lbf Cable Retention Force: 40 lbf Standards RG Type: 59 Applicable Environmental and Other Programs Environmental Space: Indoor/Outdoor EU CE Mark: Yes Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Related Part Numbers Variants Item # Color UPC FSNS59BNCU-25 No Color 845671002584 Patent: This product has one or more applicable patents. More information on patents can be found at https://www.belden.com/resources/patents. Product Notes Notes: All Belden ProSNS connectors meet or exceed SCTE return loss standards. History Update and Revision: Revision Number: 0.125 Revision Date: 03-03-2022 © 2022 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
FSNS59BNCU-25 价格&库存
很抱歉,暂时无法提供与“FSNS59BNCU-25”相匹配的价格&库存,您可以联系我们找货
