Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1279P Coax - Mini Hi-Res Component Video Cable
For more Information
please call
1-800-Belden1
General Description:
25 AWG solid .018” tinned copper conductors, FFEP insulation, Duobond® foil plus a tinned copper
interlocked serve shield (95% coverage), PVC inner jackets, PVC jacket.
Usage (Overall)
Suitable Applications:
RGB Projectors, LCD Projectors, Video Distribution, Component Video, Graphic Displays, Special Effects
Editing, Animation, Video Post Production, Home Theater, Offices, Boardrooms, Auditoriums,
Teleconferencing, Theaters
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material Dia. (in.)
5
25
Solid
TC - Tinned Copper .018
Total Number of Conductors:
5
Insulation
Insulation Material:
Insulation Material Dia. (in.)
FFEP - Foam FEP
0.074
Inner Shield
Inner Shield Material:
Layer # Inner Shield Trade Name Type
1
Aluminum Foil-Poly Tape-AluminumLightly bonded to dielectric 100
Duobond®
Tape
2
Coverage (%)
Interlocked Serve TC - Tinned Copper
95
Inner Jacket
Inner Jacket Material:
Nom. Dia. (in.)
PVC - Polyvinyl Chloride 0.111
Inner Jacket Color Code Chart:
Number Color
1
Red
2
Green
3
Blue
4
Yellow
5
Black
Outer Jacket
Outer Jacket Material:
Overall Cable
Overall Nominal Diameter:
0.330 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-20°C To +75°C
UL Temperature Rating:
60°C
Non-UL Temperature Rating:
75°C
Bulk Cable Weight:
60 lbs/1000 ft.
Max. Recommended Pulling Tension:
83 lbs.
Min. Bend Radius (Each Coax):
1.100 in.
Min. Bend Radius (Overall):
3.250 in.
Page 1 of 3
01-05-2017
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMP
CEC/C(UL) Specification:
CMP
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
No
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
NFPA 262
CSA Flame Test:
FT6
Suitability
Suitability - Indoor:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
Yes
Non-Plenum Number:
1279R
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
.087
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
16.8
Nominal Velocity of Propagation:
VP (%)
81
Nominal Delay:
Delay (ns/ft)
1.26
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
34
Nom. Inner Shield DC Resistance:
5.4
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
0.50
5
1.2
50
3.8
100
5.2
200
7.1
400
10.0
750
14.3
1000
16.9
2250
25.5
3000
33.9
Max. Operating Voltage - UL:
Page 2 of 3
01-05-2017
Voltage
300 V RMS
Max. Operating Voltage - Non-UL:
Voltage
300 V RMS
Minimum Return Loss:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB)
5
850
Sweep Test
Sweep Testing:
5 - 850 MHz
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1279P 0081000
1,000 FT
66.000 LB
GRAY
C
5 #25 FFEP SH FLRST FLRST
1279P 008250
250 FT
18.250 LB
GRAY
C
1279P 008500
500 FT
33.500 LB
GRAY
C
1279P 0101000
1,000 FT
66.000 LB
BLACK
C
1279P 010250
250 FT
18.250 LB
BLACK
C
1279P 010500
500 FT
33.500 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 5
Revision Date: 08-01-2013
© 2017 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Page 3 of 3
01-05-2017
很抱歉,暂时无法提供与“1279P 0081000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+40.557021000+5.25697
