Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
1411R Multi-Conductor - CMR Rated Cables
For more Information
please call
1-800-Belden1
General Description:
24 AWG stranded (7x30) TC conductor, polyolefin insulation, individually shielded Beldfoil® (100%
coverage) numbered/color-coded PVC jackets, jackets and shields bonded to strip simultaneously, overall
Beldfoil shield and 18 AWG TC drain wire.
Physical Characteristics (Overall)
Conductor
AWG:
# Pairs AWG Stranding Conductor Material Dia. (in.)
12
24
7x32
TC - Tinned Copper .024
Total Number of Conductors:
24
Insulation
Insulation Material:
Insulation Material Dia. (in.)
PO - Polyolefin
.040
Inner Shield
Inner Shield Material:
Inner Shield Trade Name Type Inner Shield Material
Beldfoil®
Coverage (%)
Tape Aluminum Foil-Polyester Tape 100
Inner Shield Drain Wire AWG:
AWG
24
Inner Shield Drain Wire Stranding:
7x32
Inner Shield Drain Wire Conductor Material:
TC - Tinned Copper
Inner Jacket
Inner Jacket Material:
Nom. Dia. (in.)
PVC - Polyvinyl Chloride .111
Outer Shield
Outer Shield Material:
Outer Shield Trade Name Type Outer Shield Material
Beldfoil®
Coverage (%)
Outer Shield Drain Wire AWG:
AWG Stranding Drain Wire Conductor Material
18
7x26
TC - Tinned Copper
Outer Jacket
Outer Jacket Material:
Outer Jacket Ripcord:
Yes
Overall Cable
Overall Cabling Color Code Chart:
Number Color
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Purple
8
Gray
9
White
Page 1 of 3
08-26-2016
10
Black
11
Tan
12
Pink
Overall Nominal Diameter:
0.555 in.
Pair
Pair Color Code Chart:
Number Color
1
Red
2
Black
Mechanical Characteristics (Overall)
Operating Temperature Range:
-30°C To +75°C
Bulk Cable Weight:
165 lbs/1000 ft.
Max. Recommended Pulling Tension:
220 lbs.
Min. Bend Radius/Minor Axis:
5.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMR
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
UL1666 Riser
CSA Flame Test:
FT4
Plenum/Non-Plenum
Plenum (Y/N):
No
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
50
Nom. Inductance:
Inductance (µH/ft)
.18
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
31
Nom. Capacitance Cond. to Other Conductor & Shield:
Capacitance (pF/ft)
58
Nominal Velocity of Propagation:
VP (%)
66
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
23.3
Nominal Outer Shield DC Resistance:
6
Page 2 of 3
08-26-2016
Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C:
15.900 Ohm/1000 ft
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
1.05 Amps per conductor @ 25°C
Notes (Overall)
Notes: Pair jackets and shields bonded so both strip simultaneously. Beldfoil® provides high reliability with ease of termination.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
1411R 0101000
1,000 FT
172.000 LB
BLACK
C
12 #24 PR BFS PVC FS PVC
1411R 010500
500 FT
91.000 LB
BLACK
C
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 1
Revision Date: 09-11-2012
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“1411R 0101000”相匹配的价格&库存,您可以联系我们找货
