1522A 0101000
1522A 0101000
    BELDEN
    5 #30 FHDPE BRD PVC FS PVC
1522A 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1522A Coax - Bundled RGB Coaxial Cables Miniature For more Information please call 1-800-Belden1 General Description: 30 AWG stranded (7x38) .012" TC conductors, foam HDPE insulation, coaxes w/Duofoil® + TC braid (90% coverage), overall Beldfoil® shield, overall PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 5 30 7x38 TC - Tinned Copper .013 Total Number of Conductors: 5 Insulation Insulation Material: Insulation Material Dia. (in.) FHDPE - Foam High Density Polyethylene .056 Inner Shield Inner Shield Material: Layer # Inner Shield Trade Name Type Inner Shield Material 1 Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 2 Braid TC - Tinned Copper 90 Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride .102 Inner Jacket Color Code Chart: Number Color 1 Red 2 Green 3 Blue 4 White 5 Yellow Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.338 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 1354) Bulk Cable Weight: 63 lbs/1000 ft. Max. Recommended Pulling Tension: 70 lbs. Min. Bend Radius/Minor Axis: 3.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2 Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1522A Coax - Bundled RGB Coaxial Cables Miniature AWM Specification: UL Style 1354 (each coax); UL Style 2688 (overall) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: Mini Suitability Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 17.3 Nominal Velocity of Propagation: VP (%) 78 Nominal Delay: Delay (ns/ft) 1.30 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 100.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.5 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.8 5 1.5 10 2.2 30 4.0 50 5.4 100 8.2 200 12.5 400 18.9 700 26.5 900 30.8 1000 32.8 Max. Operating Voltage - UL: Voltage 30 V RMS (UL AWM Style 1354) 300 V RMS (CL2) Minimum Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 10 40 25 Sweep Test Sweep Testing: 100% sweep tested 10 MHz to 40 MHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Page 2 of 3 Item Desc 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1522A Coax - Bundled RGB Coaxial Cables Miniature 1522A 0101000 1,000 FT 67.000 LB BLACK C 5 #30 FHDPE BRD PVC FS PVC 1522A 010500 500 FT 34.500 LB BLACK C 5 #30 FHDPE BRD PVC FS PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 04-11-2008 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-05-2017
1522A 0101000 价格&库存
很抱歉,暂时无法提供与“1522A 0101000”相匹配的价格&库存,您可以联系我们找货
