1694SB 0101000
1694SB 0101000
    BELDEN
    BELDEN - 1694SB 0101000 - CABLE, COAXIAL, RG-6/U, 18AWG, 75 OHM, 1
1694SB 0101000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1694SB Coax - Shipboard Precision Video Cable - Analog/Digital Application For more Information please call 1-800-Belden1 General Description: 18 AWG solid .040" bare copper conductor, gas-injected foam HDPE insulation, Duofoil® (100% coverage) plus a tinned copper braid shield (95% coverage), LSZH jacket. Usage (Overall) Suitable Applications: Coaxial Cable for Communication, Audio, Video, CCTV, CATV, MATV, Broadband, or Broadcast use in Marine Shipboard and Offshore use Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (in.) 1 18 Solid BC - Bare Copper .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FHDPE - Foam High Density Polyethylene .180 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Duofoil® 2 Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material LSZH - Low Smoke Zero Halogen Overall Cable Overall Nominal Diameter: 0.274 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Bulk Cable Weight: 42 lbs/1000 ft. Max. Recommended Pulling Tension: 69 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG-LS CEC/C(UL) Specification: CMG-LS EU Directive 2011/65/EU (ROHS II): Yes IEEE Specification: Std. 45 clause 23 EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 08/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1694SB Coax - Shipboard Precision Video Cable - Analog/Digital Application MII Order #39 (China RoHS): Yes Other Specification: UL444, ABS Type Approval Certificate 05-HS500072C RG Type: 6/U Flame Test UL Flame Test: UL1685 FT4 Loading, Limited Smoke CSA Flame Test: FT4 IEC Flame Test: 60332-1, 60332-3-22 (Category A) IEEE Flame Test: 1202 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Sunlight Resistance: Yes Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) 0.106 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.24 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.4 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.8 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1.000 0.240 3.580 0.440 5.000 0.520 7.000 0.610 10.000 0.710 67.500 1.650 71.500 1.690 88.500 1.860 100.000 1.950 135.000 2.240 143.000 2.300 180.000 2.570 270.000 3.170 360.000 3.690 540.000 4.600 720.000 5.380 750.000 5.500 1000.000 6.420 1500.000 7.990 2000.000 9.370 2250.000 10.010 3000.000 11.780 4500.000 14.920 Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1694SB Coax - Shipboard Precision Video Cable - Analog/Digital Application Max. Operating Voltage - UL: Voltage 300 V RMS Other Electrical Characteristic 1: Impedance tested in accordance with ASTM D-4566 paragraph 43.2, option 2 using a 75 Ohm fixed bridge and termination. 75 +/- 1.5 Ohms Other Electrical Characteristic 2: Return Loss tested in accordance with ASTM D-4566 paragraph 45.3, using a 75 Ohm fixed bridge and termination. Minimum Return Loss: Start Freq. (MHz) Stop Freq. (MHz) Min. RL (dB) 5 1600 23 1600 4500 21 Sweep Test Sweep Testing: 100% Sweep tested 5 MHz to 4.5 GHz. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1694SB 0101000 1,000 FT 46.000 LB BLACK C #18 PE/GIFHDPE SH FRNHPO Notes: C = CRATE REEL PUT-UP. Revision Number: 6 Revision Date: 09-24-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
1694SB 0101000 价格&库存
很抱歉,暂时无法提供与“1694SB 0101000”相匹配的价格&库存,您可以联系我们找货
