1700A 010U1000
1700A 010U1000
    BELDEN
    CAT5E+ 4PRB U/UTP CMR BOX
1700A 010U1000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1700A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable For more Information please call 1-800-Belden1 General Description: CAT5e+ (350MHz), 4-Bonded-Pair, U/UTP-Unshielded, Riser-CMR, Premise Horizontal Cable, 24 AWG Solid Bare Copper Conductors, Polyolefin Insulation, Ripcord, PVC Jacket Usage (Overall) Suitable Applications: Premise Horizontal Cable, Gigabit Ethernet, POE, POE+,100BaseTX, 100BaseVG ANYLAN, 155ATM, 622ATM, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments , CMR, Riser Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 24 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material PO - Polyolefin Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.200 Outer Jacket Ripcord: Yes Overall Cable Overall Nominal Diameter: 0.200 in. Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe & Blue 2 White/Orange Stripe & Orange 3 White/Green Stripe & Green 4 White/Brown Stripe & Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: 0°C To +60°C Operating Temperature Range: -20°C To +60°C Bulk Cable Weight: 21 lbs/1000 ft. Max. Recommended Pulling Tension: 40 lbs. Min. Bend Radius/Minor Axis: 0.500 in. Min. Bend/Installation: 2 in. Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1700A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMR CEC/C(UL) Specification: CMR EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 5e - TIA 568.C.2 Other Specification: NEMA WC-63.1 Category 5e, UL Verified to Category 5e Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: UL1666 Vertical Riser C(UL) Flame Test: FT4 IEC Flame Test: 60332-3-24 (Category C) IEEE Flame Test: 1202 Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 1701A Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 15 Maximum Capacitance Unbalance (pF/100 m): 66 Nominal Velocity of Propagation: VP (%) 70 Maximum Delay: Delay (ns/100 m) 510 Max. Delay Skew: Delay Skew (ns/100 m) 25 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 9 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Freq. (MHz) Max. Attenuation (dB/100 m) Min. PSNEXT (dB) Min. PSACR (dB) Min RL (dB) 1 2.000 69.3 67.3 20.000 4 4.000 60.3 56.3 23.000 Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1700A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable 8 5.700 55.8 50.1 24.500 10 6.400 54.3 47.9 25.000 16 8.100 51.2 43.1 25.000 20 9.100 49.8 40.7 25.000 25 10.200 48.3 38.2 25.000 31.25 11.400 46.9 35.5 25.000 62.5 16.400 42.4 26.0 25.000 100 21.000 39.3 18.3 25.000 155 26.600 36.4 9.8 19.000 200 30.400 34.8 4.4 19.000 250 34.400 32.3 >0 18.000 300 38.000 28.1 18.000 350 41.400 27.1 17.000 400 44.500 26.3 17.000 450 47.600 25.5 17.000 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. PSACRF (dB) 1 100 ± 12 105 ± 10 65.8 4 100 ± 12 100 ± 10 53.8 8 100 ± 12 100 ± 10 47.7 10 100 ± 12 100 ± 10 45.8 16 100 ± 12 100 ± 10 41.7 20 100 ± 12 100 ± 10 39.8 25 100 ± 15 100 ± 10 37.8 31.25 100 ± 15 100 ± 10 35.9 62.5 100 ± 15 100 ± 10 29.9 100 100 ± 15 100 ± 10 25.8 155 100 ± 18 100 ± 10 22.0 200 100 ± 18 100 ± 10 19.8 250 100 ± 20 100 ± 10 17.8 300 100 ± 20 100 ± 10 14.3 350 100 ± 22 100 ± 10 12.9 400 100 ± 22 100 ± 10 11.8 450 100 ± 22 100 ± 10 10.7 Premise Cable Electrical Table 4: Frequency (MHz) Min. TCL (dB) Min. ELTCTL (dB) 1.000 40.000 35.000 4.000 40.000 23.000 8.000 40.000 16.900 10.000 40.000 15.000 16.000 38.000 10.900 20.000 37.000 9.000 25.000 36.000 7.000 31.250 35.100 62.500 32.000 100.000 30.000 155.000 28.100 200.000 27.000 250.000 26.000 Notes (Overall) Notes: Belden IBDN. Jacket sequentially marked at 2 ft. intervals. Third party verified to ANSI/TIA-568-C.2 Category 5e. Values above 350 MHz are for Engineering Information Only Put Ups and Colors: Item # Putup Ship Weight Color 1700A B02U1000 1,000 FT 22.000 LB PURPLE Notes Item Desc 1700A B021000 1,000 FT 22.000 LB PURPLE 1700A F2VU1000 1,000 FT 22.000 LB GRAY, DEC 1700A F2V1000 1,000 FT 22.000 LB GRAY, DEC C CAT5E+ 4PRB U/UTP CMR REEL 1700A F2V3000 3,000 FT 66.000 LB GRAY, DEC C CAT5E+ 4PRB U/UTP CMR REEL 1700A 002U1000 1,000 FT 22.000 LB RED 1700A 0021000 1,000 FT 22.000 LB RED C CAT5E+ 4PRB U/UTP CMR REEL 1700A 0023000 3,000 FT 66.000 LB RED C CAT5E+ 4PRB U/UTP CMR REEL 1700A 003U1000 1,000 FT 22.000 LB ORANGE 1700A 0031000 1,000 FT 22.000 LB ORANGE CAT5E+ 4PRB U/UTP CMR BOX C CAT5E+ 4PRB U/UTP CMR REEL CAT5E+ 4PRB U/UTP CMR BOX CAT5E+ 4PRB U/UTP CMR BOX Page 3 of 4 CAT5E+ 4PRB U/UTP CMR BOX C CAT5E+ 4PRB U/UTP CMR REEL 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1700A Multi-Conductor - Enhanced Category 5E Bonded-Pair Cable 1700A 004U1000 1,000 FT 22.000 LB YELLOW 1700A 005U1000 1,000 FT 22.000 LB GREEN, DARK CAT5E+ 4PRB U/UTP CMR BOX 1700A 0051000 1,000 FT 22.000 LB GREEN, DARK 1700A 006U1000 1,000 FT 22.000 LB BLUE, LIGHT 1700A 0061640 1,640 FT 36.080 LB BLUE, LIGHT C CAT5E+ 4PRB U/UTP CMR REEL 1700A 0063000 3,000 FT 66.000 LB BLUE, LIGHT C CAT5E+ 4PRB U/UTP CMR REEL 1700A 008U1000 1,000 FT 22.000 LB GRAY 1700A 009U1000 1,000 FT 22.000 LB WHITE C CAT5E+ 4PRB U/UTP CMR BOX 1700A 0091000 1,000 FT 22.000 LB WHITE C CAT5E+ 4PRB U/UTP CMR REEL 1700A 0093000 3,000 FT 66.000 LB WHITE C CAT5E+ 4PRB U/UTP CMR REEL 1700A 010U1000 1,000 FT 22.000 LB BLACK 1700A 0101000 1,000 FT 22.000 LB BLACK CAT5E+ 4PRB U/UTP CMR BOX C CAT5E+ 4PRB U/UTP CMR REEL CAT5E+ 4PRB U/UTP CMR BOX CAT5E+ 4PRB U/UTP CMR BOX CAT5E+ 4PRB U/UTP CMR BOX C CAT5E+ 4PRB U/UTP CMR REEL Notes: C = CRATE REEL PUT-UP. Revision Number: 10 Revision Date: 06-09-2016 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 4 of 4 02-01-2017
1700A 010U1000 价格&库存
很抱歉,暂时无法提供与“1700A 010U1000”相匹配的价格&库存,您可以联系我们找货
1700A 010U1000
  • 1000+3.179251000+0.41330
