1902A B59250
1902A B59250
    BELDEN
    2#24 JKTD PR PVC
1902A B59250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1902A Multi-Conductor - FleXnake® Super-Flexible, High-Performance Cable For more Information please call 1-800-Belden1 General Description: 24 AWG stranded (41x40) bare copper conductor, polyolefin insulation, individually shielded with double serve “French Braid” (95% coverage), TC drain wire, numbered/color-coded PVC jackets, overall Black PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 2 24 41x40 BC - Bare Copper .0225 Total Number of Conductors: 4 Insulation Insulation Material: Insulation Material Dia. (in.) PO - Polyolefin 0.040 Inner Shield Inner Shield Material: Type Inner Shield Material Coverage (%) French Braid BC - Bare Copper 95 Inner Shield Drain Wire AWG: AWG 24 Inner Shield Drain Wire Stranding: 19x26 Inner Shield Drain Wire Conductor Material: TC - Tinned Copper Inner Jacket Inner Jacket Material: Inner Jacket Material Nom. Dia. (in.) PVC - Polyvinyl Chloride 0.119 Inner Jacket Color Code Chart: Number Color 1 Brown 2 Red Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.330 in. Pair Pair Color Code Chart: Number Color 1 Red & Black Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Bulk Cable Weight: 48 lbs/1000 ft. Max. Recommended Pulling Tension: 58 lbs. Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1902A Multi-Conductor - FleXnake® Super-Flexible, High-Performance Cable Min. Bend Radius/Minor Axis: 3.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 60 Nom. Inductance: Inductance (µH/ft) .18 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 26.1 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 47.5 Nominal Velocity of Propagation: VP (%) 66 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 25.5 Ind. Pair Nominal Shield DC Resistance @ 20 Deg. C: 7.200 Ohm/1000 ft Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 1.05 Amps per conductor @ 25°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 1902A B591000 1,000 FT 53.000 LB BLACK, MATTE C 2#24 JKTD PR PVC 1902A B59250 250 FT 13.750 LB BLACK, MATTE C 2#24 JKTD PR PVC 1902A B59500 500 FT 27.500 LB BLACK, MATTE 2#24 JKTD PR PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 10-04-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the Page 2 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 1902A Multi-Conductor - FleXnake® Super-Flexible, High-Performance Cable correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 08-26-2016
1902A B59250 价格&库存
很抱歉,暂时无法提供与“1902A B59250”相匹配的价格&库存,您可以联系我们找货
