19348 010250
19348 010250
    BELDEN
    CBL 3COND 18AWG
19348 010250 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 19348 Portable Cordage - UL/CSA Types: SJO, SJT For more Information please call 1-800-Belden1 General Description: SJT PVC jacket, 300V, 60ºC, paper tape separator, serrated jacket, UL/CSA listed, color code: black, white, green (18 AWG); black, white, green/yellow (16 AWG). Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 3 18 42x34 BC - Bare Copper Total Number of Conductors: 3 Type of Cordage: SJT Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .032 Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .046 Overall Cable Overall Cabling Fillers: Paper Overall Cabling Color Code Chart: Color Black White Green Overall Cabling Separator Material: Paper Tape Overall Nominal Diameter: 0.328 in. Mechanical Characteristics (Overall) UL Temperature Rating: 60°C Bulk Cable Weight: 63 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: SJT CSA Specification: SJT EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 19348 Portable Cordage - UL/CSA Types: SJO, SJT MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Surface Printing (Overall) Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 10 Amps per conductor @ 25°C 7 Amps per conductor @ 25°C over 50 ft. Dielectric Withstand Voltage: 1500 V AC Applied For 1 Min. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 19348 010250 250 FT 17.250 LB BLACK CF 3#18 PVC TYP SJT Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' Revision Number: 2 Revision Date: 09-10-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
19348 010250 价格&库存
很抱歉,暂时无法提供与“19348 010250”相匹配的价格&库存,您可以联系我们找货
  • 250+41.56601250+5.21447
  • 500+39.48584500+4.95351
  • 750+38.30795750+4.80575
  • 1250+36.863711250+4.62456
  • 1750+35.935401750+4.50811
  • 2500+35.517982500+4.45574
库存:250
