2413F D15A500
2413F D15A500
    BELDEN
    BELDEN - 2413F D15A500 - SHIELDED CABLE MULTIPAIR, 4PAIR, 23AWG, 500FT, 300V
2413F D15A500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2413F Multi-Conductor - Enhanced Category 6 Nonbonded-Pair ScTP Cable For more Information please call 1-800-Belden1 General Description: CAT6+, (350 MHz) 4-Pair, F/UTP-Foil Shielded, Plenum-CMP, Premise Horizontal Cable, 23 AWG Solid Bare Copper Conductors, FEP Insulation, Patented X-Spline, Overall Beldfoil Shield, Flamarrest® Jacket Usage (Overall) Suitable Applications: Networking Horizontal Cable, HDBaseT, 1000Base-T (Gigabit Ethernet), 100Base-T (Fast Ethernet), 10Base-T (Ethernet), 100BaseVG, ANYLAN, 155ATM, 622ATM, ANSI.X3.263 FDDI TP-PMD, NTSC/PAL Component or Composite Video, AES/EBU, Digital Video, RS-422, Noisy Environments, 250 MHz Category 6 Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 4 23 Solid BC - Bare Copper Total Number of Conductors: 8 Insulation Insulation Material: Insulation Material FEP - Fluorinated Ethylene Propylene Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 24 Solid TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Trade Name Outer Jacket Material Flamearrest(® LS PVC - Low Smoke Polyvinyl Chloride Outer Jacket Diameter: Nom. Dia. (in.) 0.285 Outer Jacket Ripcord: Yes Overall Cable Overall Cabling Fillers: Patented Central X-Spline Overall Cabling Separator Material: Polyester Tape Pair Pair Color Code Chart: Number Color 1 White/Blue Stripe and Blue 2 White/Orange Stripe and Orange 3 White/Green Stripe and Green 4 White/Brown Stripe and Brown Mechanical Characteristics (Overall) Storage Temperature Range: -20°C To +75°C Installation Temperature Range: +5°C To +50°C Operating Temperature Range: -20°C To +75°C Bulk Cable Weight: 49 lbs/1000 ft. Max. Recommended Pulling Tension: 25 lbs. Page 1 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2413F Multi-Conductor - Enhanced Category 6 Nonbonded-Pair ScTP Cable Min. Bend Radius/Minor Axis: 1 in. Min. Bend/Installation: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMP CEC/C(UL) Specification: CMP EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 12/09/2011 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Telecommunications Standards: Category 6 - TIA 568.C.2 Other Specification: UL Verified to Category 6 Applicable Patents: Country www.belden.com/p Flame Test UL Flame Test: NFPA 262 Plenum Flame Test (UL910)(FT6) C(UL) Flame Test: FT6 CSA Flame Test: FT6 Plenum/Non-Plenum Plenum (Y/N): Yes Non-Plenum Number: 2412F Electrical Characteristics (Overall) Nom. Mutual Capacitance: Capacitance (pF/ft) 14.000 Maximum Capacitance Unbalance: Capacitance (pF/ft) 66.000 Nominal Velocity of Propagation: VP (%) 72.000 Maximum Delay: Delay (ns/100 m) 537.000 Max. Delay Skew: Delay Skew (ns/ft) 30.000 Maximum Conductor DC Resistance: DCR @ 20°C (Ohm/100 m) 8.200 Max. Operating Voltage - UL: Voltage 300 V RMS Maximum DCR Unbalanced: DCR Unbalance @ 20°C (%) 3.000 Electrical Characteristics-Premise (Overall) Premise Cable Electrical Table 1: Page 2 of 4 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2413F Multi-Conductor - Enhanced Category 6 Nonbonded-Pair ScTP Cable Freq. (MHz) Max. Attenuation (dB/100 m) Min. NEXT (dB) Min. PSNEXT (dB) Min. ACR (dB) Min. PSACR (dB) Min RL (dB) 1 2.000 75.3 73.3 73.3 72.3 20.000 4 3.700 66.3 64.3 62.6 61.6 23.000 8 5.200 63.3 61.3 58.1 57.1 24.500 10 5.800 61.8 59.8 56.0 55.0 25.000 16 7.400 58.6 56.6 51.2 50.2 25.000 20 8.300 57.1 55.1 48.8 47.8 25.000 25 9.300 55.5 53.5 46.3 45.2 24.300 31.25 10.400 54.0 52.0 43.6 42.6 23.600 62.5 15.000 49.1 47.1 34.1 33.1 21.500 100 19.300 45.8 43.8 26.5 25.5 20.800 200 28.300 40.9 38.9 12.6 11.6 18.700 250 32.100 39.3 37.3 7.2 6.2 18.000 300 35.600 38.1 36.1 2.5 1.5 17.500 350 38.900 37.1 35.1 17.000 400 42.000 36.3 34.3 16.600 450 45.000 35.5 33.5 16.200 500 47.900 34.8 32.8 15.900 550 50.600 34.2 32.2 15.600 Premise Cable Electrical Table 2: Freq. (MHz) Input (Unfitted) Imp. (Ohms) Fitted Impedance Min. ELFEXT (dB) Min. PSELFEXT (dB) 1 100 ± 15 100 ± 15 70.8 67.8 4 100 ± 15 100 ± 15 58.8 55.8 8 100 ± 15 100 ± 15 52.7 49.7 10 100 ± 15 100 ± 15 50.8 47.8 16 100 ± 15 100 ± 15 46.7 43.7 20 100 ± 15 100 ± 15 44.8 41.8 25 100 ± 15 100 ± 15 42.8 39.8 31.25 100 ± 15 100 ± 15 40.9 37.9 62.5 100 ± 15 100 ± 15 34.9 31.9 100 100 ± 15 100 ± 15 30.8 27.8 200 100 ± 22 100 ± 15 24.8 21.8 250 100 ± 32 100 ± 15 22.8 19.8 300 100 ± 32 100 ± 15 21.3 18.3 350 100 ± 32 100 ± 15 19.9 16.9 400 100 ± 32 100 ± 15 18.8 15.8 450 100 ± 32 100 ± 15 17.7 14.7 500 100 ± 32 100 ± 15 16.8 13.8 550 100 ± 32 100 ± 15 16.0 13.0 Premise Cable Electrical Table 4: Frequency (MHz) Min. TCL (dB) Min. ELTCTL (dB) 1.000 40.000 35.000 4.000 40.000 23.000 8.000 40.000 17.000 10.000 40.000 15.000 16.000 38.000 10.900 20.000 37.000 9.000 25.000 36.000 7.100 31.250 35.100 5.100 62.500 32.000 100.000 30.000 200.000 27.000 250.000 26.000 Notes (Overall) Notes: Jacket sequentially marked at 2 ft. intervals Third party Verified to ANSI/TIA-568-C.2, Category 6. Values above 350 MHz are for Engineering Information Only. Put Ups and Colors: Item # Putup Ship Weight Color 2413F D15A1000 1,000 FT 50.000 LB BLUE Notes CAT6+ 4PR F/UTP CMP RIB 2413F D15A500 500 FT 27.500 LB BLUE CAT6+ 4PR F/UTP CMP RIB 2413F D151000 1,000 FT 49.000 LB BLUE CAT6+ 4PR F/UTP CMP REEL 2413F 0021000 1,000 FT 49.000 LB RED CAT6+ 4PR F/UTP CMP REEL 2413F 0031000 1,000 FT 49.000 LB ORANGE CAT6+ 4PR F/UTP CMP REEL 2413F 0041000 1,000 FT 49.000 LB YELLOW CAT6+ 4PR F/UTP CMP REEL Page 3 of 4 Item Desc 02-01-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 2413F Multi-Conductor - Enhanced Category 6 Nonbonded-Pair ScTP Cable 2413F 0051000 1,000 FT 49.000 LB GREEN, DARK CAT6+ 4PR F/UTP CMP REEL 2413F 0081000 1,000 FT 49.000 LB GRAY CAT6+ 4PR F/UTP CMP REEL 2413F 009A1000 1,000 FT 50.000 LB WHITE CAT6+ 4PR F/UTP CMP RIB 2413F 009A500 500 FT 27.500 LB WHITE CAT6+ 4PR F/UTP CMP RIB 2413F 0091000 1,000 FT 49.000 LB WHITE CAT6+ 4PR F/UTP CMP REEL 2413F 010A1000 1,000 FT 50.000 LB BLACK CAT6+ 4PR F/UTP CMP RIB 2413F 0101000 1,000 FT 49.000 LB BLACK CAT6+ 4PR F/UTP CMP REEL Revision Number: 3 Revision Date: 09-25-2014 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 4 of 4 02-01-2017
2413F D15A500 价格&库存
很抱歉,暂时无法提供与“2413F D15A500”相匹配的价格&库存,您可以联系我们找货
