3092A 0102000
3092A 0102000
    BELDEN
    COAX 18AWG 100 OHM
3092A 0102000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3092A Coax - ControlNet™ Quad Shielded Coax For more Information please call 1-800-Belden1 General Description: 18 AWG solid bare copper-covered steel conductor, foam polyethylene insulation, Duobond® IV Quad Shield (100% coverage), PVC Jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 18 Solid Dia. (in.) BCCS - Bare Copper Covered Steel .040 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (in.) Gas-injected FPE - Foam Polyethylene .180 Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Bonded Duofoil® 2 3 Duofoil® 4 Coverage (%) Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid AL - Aluminum 60 Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Braid AL - Aluminum 40 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.298 in. Mechanical Characteristics (Overall) Operating Temperature Range: -30°C To +75°C Bulk Cable Weight: 33 lbs/1000 ft. Max. Recommended Pulling Tension: 162 lbs. Min. Bend Radius/Minor Axis: 3 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2R, CMG, CMR CEC/C(UL) Specification: CMG EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 6/U Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3092A Coax - ControlNet™ Quad Shielded Coax Flame Test UL Flame Test: UL1666 Vertical Shaft Suitability Sunlight Resistance: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 3093A Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 75 Nom. Inductance: Inductance (µH/ft) .097 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 16.2 Nominal Velocity of Propagation: VP (%) 82 Nominal Delay: Delay (ns/ft) 1.28 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 28.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 3.6 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 .35 2 .38 5 .45 10 .59 20 .86 50 1.37 100 1.97 200 2.82 300 3.48 400 4.04 Max. Operating Voltage - UL: Voltage 300 V RMS Minimum Structural Return Loss: Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB) 5 50 23 Notes (Overall) Notes: CPE jacket or LSZH jacket also available as special products. Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 3092A X7E1000 1,000 FT 37.000 LB BLUE X7E C #18 GIFHDLDPE DBSH PVC 3092A X7E2000 2,000 FT 82.000 LB BLUE X7E C #18 GIFHDLDPE DBSH PVC 3092A X7E500 500 FT 20.500 LB BLUE X7E 3092A X7E5000 5,000 FT 190.000 LB BLUE X7E 3092A 0021000 1,000 FT 41.000 LB RED C #18 GIFHDLDPE DBSH PVC 3092A 0101000 1,000 FT 37.000 LB BLACK C #18 GIFHDLDPE DBSH PVC 3092A 01010000 10,000 FT 400.000 LB BLACK 3092A 0102000 2,000 FT 82.000 LB BLACK Page 2 of 3 #18 GIFHDLDPE DBSH PVC #18 GIFHDLDPE DBSH PVC #18 GIFHDLDPE DBSH PVC C #18 GIFHDLDPE DBSH PVC 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 3092A Coax - ControlNet™ Quad Shielded Coax 3092A 0102500 2,500 FT 100.000 LB BLACK 3092A 010500 500 FT 20.500 LB BLACK C #18 GIFHDLDPE DBSH PVC #18 GIFHDLDPE DBSH PVC 3092A 0105000 5,000 FT 190.000 LB BLACK #18 GIFHDLDPE DBSH PVC Notes: C = CRATE REEL PUT-UP. Revision Number: 4 Revision Date: 09-04-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
3092A 0102000 价格&库存
很抱歉,暂时无法提供与“3092A 0102000”相匹配的价格&库存,您可以联系我们找货
