Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
3092A Coax - ControlNet™ Quad Shielded Coax
For more Information
please call
1-800-Belden1
General Description:
18 AWG solid bare copper-covered steel conductor, foam polyethylene insulation, Duobond® IV Quad
Shield (100% coverage), PVC Jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Coax AWG Stranding Conductor Material
1
18
Solid
Dia. (in.)
BCCS - Bare Copper Covered Steel .040
Total Number of Conductors:
1
Insulation
Insulation Material:
Insulation Material
Dia. (in.)
Gas-injected FPE - Foam Polyethylene .180
Outer Shield
Outer Shield Material:
Layer # Outer Shield Trade Name Type Outer Shield Material
1
Bonded Duofoil®
2
3
Duofoil®
4
Coverage (%)
Tape Bonded Aluminum Foil-Polyester Tape-Aluminum Foil 100
Braid AL - Aluminum
60
Tape Aluminum Foil-Polyester Tape-Aluminum Foil
100
Braid AL - Aluminum
40
Outer Jacket
Outer Jacket Material:
PVC - Polyvinyl Chloride
Overall Cable
Overall Nominal Diameter:
0.298 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
-30°C To +75°C
Bulk Cable Weight:
33 lbs/1000 ft.
Max. Recommended Pulling Tension:
162 lbs.
Min. Bend Radius/Minor Axis:
3 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CL2R, CMG, CMR
CEC/C(UL) Specification:
CMG
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
01/01/2004
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
MII Order #39 (China RoHS):
Yes
RG Type:
6/U
Page 1 of 3
08-26-2016
Flame Test
UL Flame Test:
UL1666 Vertical Shaft
Suitability
Sunlight Resistance:
Yes
Plenum/Non-Plenum
Plenum (Y/N):
No
Plenum Number:
3093A
Electrical Characteristics (Overall)
Nom. Characteristic Impedance:
Impedance (Ohm)
75
Nom. Inductance:
Inductance (µH/ft)
.097
Nom. Capacitance Conductor to Shield:
Capacitance (pF/ft)
16.2
Nominal Velocity of Propagation:
VP (%)
82
Nominal Delay:
Delay (ns/ft)
1.28
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
28.0
Nominal Outer Shield DC Resistance:
3.6
Nom. Attenuation:
Freq. (MHz) Attenuation (dB/100 ft.)
1
.35
2
.38
5
.45
10
.59
50
1.37
100
1.97
200
2.82
300
3.48
400
4.04
Max. Operating Voltage - UL:
Voltage
300 V RMS
Minimum Structural Return Loss:
Description Freq. (MHz) Start Freq. (MHz) Stop Freq. (MHz) Min. SRL (dB)
5
50
23
Notes (Overall)
Notes: CPE jacket or LSZH jacket also available as special products.
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
Notes
Item Desc
3092A X7E1000
1,000 FT
37.000 LB
BLUE X7E
C
#18 GIFHDLDPE DBSH PVC
3092A X7E2000
2,000 FT
82.000 LB
BLUE X7E
C
3092A X7E500
500 FT
20.500 LB
BLUE X7E
3092A X7E5000
5,000 FT
190.000 LB
BLUE X7E
3092A 0021000
1,000 FT
41.000 LB
RED
C
3092A 0101000
1,000 FT
37.000 LB
BLACK
C
3092A 01010000
10,000 FT
400.000 LB
BLACK
3092A 0102000
2,000 FT
82.000 LB
BLACK
Page 2 of 3
C
08-26-2016
3092A 0102500
2,500 FT
100.000 LB
BLACK
3092A 010500
500 FT
20.500 LB
BLACK
C
3092A 0105000
5,000 FT
190.000 LB
BLACK
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 4
Revision Date: 09-04-2013
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 3 of 3
08-26-2016
很抱歉,暂时无法提供与“3092A X7E500”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+31.19616500+3.91357
- 国内价格 香港价格
- 1+79.086331+9.92140
- 50+62.6925850+7.86480
- 100+56.11707100+7.03990
- 152+49.54155152+6.21500
