Product Bulletin
RS-485 Direct Burial
UL-Rated Industrial Cable
The first of its kind, this UL Direct Burial rated, waterblocking RS-485 cable is installable directly underground
without a separate conduit, saving you set-up time,
material, and labor costs.
Achieve reliable, long-distance installation with low
capacitance and prevent data distortion or errors.
Protect against harsh elements with a unique waterblocking and water-resistant construction as well as
UV, oil, noise, fire and crush resistance.
Save time and money – no underground conduit
needed in installation
Belden’s RS-485 Direct Burial cable is well-suited for any application requiring
reliable communication amidst exposure to water, sun and risks of flammability.
Key Features
• Water-blocking and water-resistant
jacket design protects against
exposure to moisture and water
• Crush resistance and UL direct burial
rating for underground installation
• Sun resistance makes cable ideal for
use in outdoor environments
• 300V PLTC rating for use in power
limited trays
• CM rating for flame resistance
• Low-capacitance and noise
protection for use across long
distances and remote applications
Your Benefits
System integrators and installers can reduce network installation costs and hassles in the field with Belden’s UL-rated RS-485 Direct
Burial cable. Built with a water-blocking construction, the cable does not require a separate conduit to protect it from the elements
when buried underground.
In addition to robust water protection, the 300V PLTC rating enables use of the cable in power limited trays. The UL UV resistance
and CM fire resistance ratings also keep the cable safe in outdoor environments.
The low capacitance of the RS-485 Direct Burial cable means it can reliably perform over long distances without data distortion or
transmission errors, such as when network communication between factories or plants is required.
Applications
Markets
Specifically designed with ratings to withstand exposure to
water, fire and sunlight, the RS-485 Direct Burial cable is ideal
for settings that require reliable performance underground.
Any remote application that relies on strong signals over
long distances, like solar plant and outdoor lighting systems
that require 120 Ohm direct burial cables are an ideal fit for
this cabling.
Belden’s RS-485 Direct Burial cable benefits a wide range of
markets such as energy, mining, water/wastewater, general
manufacturing, oil and gas, security, transportation and mass
transit, airport and seaport industries.
Belden’s RS-485 Direct Burial cable comes with low-capacitance and water-blocking
features for safe installation underground and reliable performance over long distances.
OD Nom
Product
Code
Item Number
Pairs
Inch
mm
3105DB
3105DB 0101000
1
0.338
8.585
1000 ft
3106DB
3106DB 0101000
1.5
0.364
9.246
1000 ft
3107DB
3107DB 0101000
2
0.387
9.83
1000 ft
3108DB
3108DB 0101000
3
0.411
10.439
1000 ft
3109DB
3109DB 0101000
4
0.484
12.294
1000 ft
3105DB
3105DB 0105000
1
0.338
8.585
5000 ft
3106DB
3106DB 0105000
1.5
0.364
9.246
5000 ft
3107DB
3107DB 0105000
2
0.387
9.83
5000 ft
3108DB
3108DB 0105000
3
0.411
10.439
5000 ft
3109DB
3109DB 0105000
4
0.484
12.294
5000 ft
Putup
Jacket
Color
Rating
Black
UL Direct
Burial,
PLTC,
CM, cUL,
Sun Res,
Outdoor,
Oil Res,
FT1, RoHS
Compliant
Nom. Capacitance
(C-to-C)
Nom. Capacitance
(C-to-Shield)
pF/ft
pF/m
pF/m
pF/m
11
36.1
20.9
68.6
For more information, visit us at www.belden.com.
Follow us on Twitter@BeldenIND. Call 1-800-BELDEN-1
Belden, Belden Sending All The Right Signals, Hirschmann, GarrettCom, Tofino Security, Lumberg Automation and the Belden logo are trademarks
or registered trademarks of Belden Inc. or its affiliated companies in the United States and other jurisdictions. Belden and other parties may also have
trademark rights in other terms used herein.
©Copyright 2019, Belden Inc.
RS-485-DIRECT-BURIAL-CABLE-PRODUCT-BULLETIN_PB00181_INCA_BDC_0219_ENG
Nom Velocity Nom Imp
of Propagation
Ω
78%
120
很抱歉,暂时无法提供与“3108DB 0101000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 305+148.04379305+19.08570
- 610+129.46162610+16.69010
