35618 0015000
35618 0015000
    BELDEN
    HOOK-UP STR 18AWG XLPE
35618 0015000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 35618 Hook-up/Lead - UL AWM Style 3173 - XL-DUR® For more Information please call 1-800-Belden1 General Description: The insulation is cross-linked polyethylene applied in a single extrusion. This construction has excellent thermal aging characteristics, moisture resistance, and solvent resistance. The 356-series of XL-DUR is recommended for class 130(B)as motor leads Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 18 16x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Min. Avg. Wall (in.) XLPE - Cross Linked Polyethylene 0.030 Overall Insulation Overall Cable Overall Nominal Diameter: 0.109 in. Mechanical Characteristics (Overall) Bulk Cable Weight: 10 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 600 V, 125°C CSA Rating: 600 V, 125°C CSA Type: CL1251 EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 07/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 6.000 Max. Operating Voltage - UL: Voltage 600 Vrms Max. Recommended Current: Description Current Single conductor in free air @ ambient 30C 22 amps Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 35618 Hook-up/Lead - UL AWM Style 3173 - XL-DUR® Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 35618 0015000 5,000 FT 50.000 LB BROWN CIUZ #18STR XLPE 125C 600VBRN 35618 002500 500 FT 5.500 LB RED F #18 STR XLPE 125C 600V 35618 0025000 5,000 FT 50.000 LB RED CIUZ #18STR XLPE 125C 600VRED 35618 0035000 5,000 FT 50.000 LB ORANGE CIUZ #18STR XLPE 125C 600VORG 35618 004500 500 FT 5.500 LB YELLOW F #18 STR XLPE 125C 600V 35618 0045000 5,000 FT 50.000 LB YELLOW CIUZ #18STR XLPE 125C 600VYEL 35618 0055000 5,000 FT 50.000 LB GREEN, DARK CIUZ #18STRXLPE 125C 600VDGRN 35618 0065000 5,000 FT 50.000 LB BLUE, LIGHT CIUZ #18STRXLPE 125C 600VLBLU 35618 0075000 5,000 FT 50.000 LB VIOLET CIUZ #18STR XLPE 125C 600VVIO 35618 0085000 5,000 FT 50.000 LB GRAY CIUZ #18STR XLPE 125C 600VGRY 35618 0095000 5,000 FT 50.000 LB WHITE CIUZ #18STR XLPE 125C 600VWHT 35618 010500 500 FT 5.500 LB BLACK F #18 STR XLPE 125C 600V 35618 0105000 5,000 FT 50.000 LB BLACK CIUZ #18STR XLPE 125C 600VBLK 35618 0125000 5,000 FT 50.000 LB PINK CIUZ #18STR XLPE 125C 600VPNK 35618 0135000 5,000 FT 50.000 LB BLUE, DARK CIUZ #18STRXLPE 125C 600VDBLU Notes: C = CRATE REEL PUT-UP. F = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50' I = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200' U = TOPCOAT ADDERS ON STOCK SOLID COLORS. MINIMUM ORDER 10000' PER COLORCOMBINATION. (SEE TOPCOAT ADDER TABLE) Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 1 Revision Date: 05-13-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
35618 0015000 价格&库存
很抱歉,暂时无法提供与“35618 0015000”相匹配的价格&库存,您可以联系我们找货
  • 5000+4.702885000+0.60629
