49733 C62S2
49733 C62S2
    BELDEN
    GPIB SHD MOLDED CABLE
49733 C62S2 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 49733 Molded Cable Assemblies - GPIB (General Purpose Interface Bus) Assembly For more Information please call 1-800-Belden1 General Description: GPIB shielded, for use with electronic equipment that is IEEE-488 compatible, molded PVC connector, S-R PVC insulation, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors # Pairs AWG Stranding Conductor Material 26 7x34 TC - Tinned Copper 10 6 26 7x34 TC - Tinned Copper 1 24 7x32 TC - Tinned Copper Total Number of Conductors: 23 Number of Pins: 24 Insulation Insulation Material: Insulation Material Wall Thickness (in.) S-R PVC - Semi-Rigid Polyvinyl Chloride 0.01 Connector Characteristics Connector Characteristics - First End # of Connector Contacts/positions: 24 Connector Characteristics - First End Connector Gender: Male/Female Connector Characteristics - First End Connector Shielding Type: Metal Backshells Connector Characteristics - First End Connector Type: Stackable Ribbon Connector Characteristics - First End Overmold Color: Gull Gray Connector Characteristics - First End Overmold Compound Material: PVC Connector Characteristics - First End Overmold Type: GPIB Connector Characteristics - First End Retention Hardware: Thumbscrews Connector Characteristics - Second End # of Connector Contacts/positions: 24 Connector Characteristics - Second End Connector Gender: Male/Female Connector Characteristics - Second End Connector Shielding Type: Metal Backshells Connector Characteristics - Second End Connector Type: Stackable Ribbon Connector Characteristics - Second End Overmold Color: Gull Gray Connector Characteristics - Second End Overmold Compound Material: PVC Connector Characteristics - Second End Overmold Type: GPIB Connector Characteristics - Second End Retention Hardware: Thumbscrews Outer Shield Outer Shield Material: Layer # Outer Shield Trade Name Type Outer Shield Material 1 Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape 100 2 Braid TC - Tinned Copper 90 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 26 7x34 TC - Tinned Copper Outer Jacket Outer Jacket Material: Page 1 of 3 01-09-2015 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 49733 Molded Cable Assemblies - GPIB (General Purpose Interface Bus) Assembly Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.035 Overall Cable Overall Nominal Diameter: 0.350 in. Assembly Dimensional Assembly Dimensional Length: 1.6 Wiring Wiring: Straight wired Wiring Diagram Color Code Chart: Number Color 1 26 AWG Single 2 26 AWG Single 3 26 AWG Single 4 26 AWG Single 5 26 AWG Single 6 26 AWG Pair1 (conductor A) 7 26 AWG Pair2 (conductor A) 8 26 AWG Pair3 (conductor A) 9 26 AWG Pair4 (conductor A) 10 26 AWG Pair5 (conductor A) 11 26 AWG Pair6 (conductor A) 12 Drain wire 13 26 AWG Single 14 26 AWG Single 15 26 AWG Single 16 26 AWG Single 17 26 AWG Single 18 26 AWG Pair1 (conductor B) 19 26 AWG Pair2 (conductor B) 20 26 AWG Pair3 (conductor B) 21 26 AWG Pair4 (conductor B) 22 26 AWG Pair5 (conductor B) 23 26 AWG Pair6 (conductor B) 24 24 AWG Single Mechanical Characteristics (Overall) UL Temperature Rating: 80°C (UL AWM Style 2464) Bulk Cable Weight: 70 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM (cable only) AWM Specification: UL Style 2464 (300 V 80°C) (cable only) EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2464) Notes (Overall) Notes: Molded connector is male/female design for easy stacking and comes with molded-in metric jackscrews. Page 2 of 3 01-09-2015 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 49733 Molded Cable Assemblies - GPIB (General Purpose Interface Bus) Assembly Put Ups and Colors: Item # Putup Ship Weight Color 49733 C62S2 1 EA 0.440 LB GRAY, GULL Revision Number: 2 Notes Item Desc GPIB SHD MOLDED CABLE RI38601 Revision Date: 07-24-2009 © 2015 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 01-09-2015
49733 C62S2 价格&库存
很抱歉,暂时无法提供与“49733 C62S2”相匹配的价格&库存,您可以联系我们找货
