4GDSY-K200
4GDSY-K200
    BELDEN
    BELDEN - 4GDSY-K200 - Multicore Cable, MachFlex 350 SY Control, Screened, 4 Core, 1.5 mm², 656 ft, 2...
4GDSY-K200 数据手册
      Technical Data Sheet – Armored (SY) PVC Control Cable MachFlex 350 SY    VDE Registered  Galvanized Steel Wire Braid (GSWB) ‐‐> Excellent Mechanical Protection  Applications  Designed  for  applications  which  are  installed  in  occasional  flexing  and  fixed  locations.  Cable  applications  include  precision  control  sensors,  multi  axis  control  machines,  temperature  controllers,  control  panels,  machine cutting tools, auxiliary equipment, motor speed control, production machinery and many more.  General Reference Standards   DIN VDE 0295, IEC 60228, BS 6360  DIN EN 50290‐2‐22, DIN VDE 0207‐363‐4‐1  IEC 60227‐5, EN 50525‐2‐51, VDE 0281‐13  DIN VDE 0482‐332‐1‐2, DIN EN 60332‐1‐2, IEC 60332‐1‐2  RoHS, REACH & CE Directives Construction & Performance  1.  Conductor Material  Stranded bare copper (DIN VDE 0295 Class 5 / IEC 60228 class 5)  2.  Insulation Material & Colour  PVC (polyvinyl  chloride), DIN VDE 0293‐1 (colour)  A) All black colour with number coding = without protective earth conductor.                        OR  B) Black colour with number coding and 1 green & yellow colour conductor = with protective earth conductor.  3.  Braid Shield Material  GSWB (Galvanized Steel Wire Braid)  4.  Jacket / Sheath Material  PVC (polyvinyl  chloride)  5.  Flame Retardancy  VDE 0482‐332‐1‐2, DIN EN 60332‐1‐2, IEC 60332‐1‐2  6.  Voltage Rating (Uo / U)  300 / 500 V  7.  Oil Resistant  DIN EN 50290‐2‐22 (TM54)  8. Temperature Range ‐30°C TO +70°C (Occasional movement)  ‐40°C TO +80°C (Fixed installation)  9. Bending Radius 20 x OD (Occasional movement)  6 x OD (Fixed installation)  10.  Other Properties  Good UV resistance, chemical resistance & flexibility  1 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.              Technical Data Sheet – Armored (SY) PVC Control Cable   Part Code  2X0.5SY  3X0.5SY  3G0.5SY  4X0.5SY  4G0.5SY  5X0.5SY  5G0.5SY  7X0.5SY  7G0.5SY  9X0.5SY  9G0.5SY  10X0.5SY  10G0.5SY  12X0.5SY  12G0.5SY  14X0.5SY  14G0.5SY  16X0.5SY  16G0.5SY  18X0.5SY  18G0.5SY  20X0.5SY  20G0.5SY  2X0.75SY  3X0.75SY  3G0.75SY  4X0.75SY  4G0.75SY  5X0.75SY  5G0.75SY  7X0.75SY  7G0.75SY  9X0.75SY  9G0.75SY  10X0.75SY  10G0.75SY  12X0.75SY  12G0.75SY  14X0.75SY  14G0.75SY  16X0.75SY  16G0.75SY  18X0.75SY  18G0.75SY  20X0.75SY  20G0.75SY        Cable  Description  2 X0.5  3 X0.5  3 G0.5  4 X0.5  4 G0.5  5 X0.5  5 G0.5  7 X0.5  7 G0.5  9 X0.5  9 G0.5  10 X0.5  10 G0.5  12 X0.5  12 G0.5  14 X0.5  14 G0.5  16 X0.5  16 G0.5  18 X0.5  18 G0.5  20 X0.5  20 G0.5  2 X0.75  3 X0.75  3 G0.75  4 X0.75  4 G0.75  5 X0.75  5 G0.75  7 X0.75  7 G0.75  9 X0.75  9 G0.75  10 X0.75  10 G0.75  12 X0.75  12 G0.75  14 X0.75  14 G0.75  16 X0.75  16 G0.75  18 X0.75  18 G0.75  20 X0.75  20 G0.75    No. Of  Cores  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20    TABLE A  Nom. Conductor  Size (mm²)  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.5  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  0.75  Nom. Cable  Diameter (mm)  7.1  7.5  7.5  8.0  8.0  8.5  8.5  9.1  9.1  10.7  10.7  11.1  11.1  11.4  11.4  11.9  11.9  12.4  12.4  13.0  13.0  13.9  13.9  7.7  8.0  8.0  8.6  8.6  9.2  9.2  9.9  9.9  11.6  11.6  12.1  12.1  12.4  12.4  13.0  13.0  13.8  13.8  14.5  14.5  15.2  15.2  Nom. Cable Weight  (kg/km)  55  79  79  92  92  106  106  124  124  158  158  173  173  190  190  210  210  232  232  256  256  288  288  81  94  94  111  111  129  129  154  154  198  198  216  216  239  239  266  266  305  305  337  337  365  365  2 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.            Technical Data Sheet – Armored (SY) PVC Control Cable Part Code  2X1.0SY  3X1.0SY  3G1.0SY  4X1.0SY  4G1.0SY  5X1.0SY  5G1.0SY  7X1.0SY  7G1.0SY  9X1.0SY  9G1.0SY  10X1.0SY  10G1.0SY  12X1.0SY  12G1.0SY  14X1.0SY  14G1.0SY  16X1.0SY  16G1.0SY  18X1.0SY  18G1.0SY  20X1.0SY  20G1.0SY  2X1.5SY  3X1.5SY  3G1.5SY  4X1.5SY  4G1.5SY  5X1.5SY  5G1.5SY  7X1.5SY  7G1.5SY  9X1.5SY  9G1.5SY  10X1.5SY  10G1.5SY  12X1.5SY  12G1.5SY  14X1.5SY  14G1.5SY  16X1.5SY  16G1.5SY  18X1.5SY  18G1.5SY  20X1.5SY  20G1.5SY  2X2.5SY  Cable  Description  2 X1.0  3 X1.0  3 G1.0  4 X1.0  4 G1.0  5 X1.0  5 G1.0  7 X1.0  7 G1.0  9 X1.0  9 G1.0  10 X1.0  10 G1.0  12 X1.0  12 G1.0  14 X1.0  14 G1.0  16 X1.0  16 G1.0  18 X1.0  18 G1.0  20 X1.0  20 G1.0  2 X1.5  3 X1.5  3 G1.5  4 X1.5  4 G1.5  5 X1.5  5 G1.5  7 X1.5  7 G1.5  9 X1.5  9 G1.5  10 X1.5  10 G1.5  12 X1.5  12 G1.5  14 X1.5  14 G1.5  16 X1.5  16 G1.5  18 X1.5  18 G1.5  20 X1.5  20 G1.5  2 X2.5  No. Of  Cores  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  Nom. Conductor  Size (mm²)  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.0  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  1.5  2.5  Nom. Cable  Diameter (mm)  8.1  8.4  8.4  9.1  9.1  9.8  9.8  10.5  10.5  12.4  12.4  12.9  12.9  13.3  13.3  14.1  14.1  14.8  14.8  15.5  15.5  16.3  16.3  8.6  9.0  9.0  9.7  9.7  10.5  10.5  11.3  11.3  13.4  13.4  14.2  14.2  14.6  14.6  15.3  15.3  16.0  16.0  16.8  16.8  17.7  17.7  10.4  Nom. Cable Weight  (kg/km)  93  109  109  129  129  152  152  184  184  236  236  258  258  287  287  331  331  369  369  408  408  442  442  108  124  124  153  153  181  181  215  215  285  285  321  321  352  352  403  403  450  450  499  499  543  543  159  3 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.            Technical Data Sheet – Armored (SY) PVC Control Cable Part Code  3X2.5SY  3G2.5SY  4X2.5SY  4G2.5SY  5X2.5SY  5G2.5SY  7X2.5SY  7G2.5SY  9X2.5SY  9G2.5SY  10X2.5SY  10G2.5SY  12X2.5SY  12G2.5SY  14X2.5SY  14G2.5SY  16X2.5SY  16G2.5SY  18X2.5SY  18G2.5SY  20X2.5SY  20G2.5SY  2X4SY  3X4SY  3G4SY  4X4SY  4G4SY  5X4SY  5G4SY  7X4SY  7G4SY  9X4SY  9G4SY  10X4SY  10G4SY  12X4SY  12G4SY  2X6SY  3X6SY  3G6SY  4X6SY  4G6SY  5X6SY  5G6SY  7X6SY  7G6SY  9X6SY  Cable  Description  3 X2.5  3 G2.5  4 X2.5  4 G2.5  5 X2.5  5 G2.5  7 X2.5  7 G2.5  9 X2.5  9 G2.5  10 X2.5  10 G2.5  12 X2.5  12 G2.5  14 X2.5  14 G2.5  16 X2.5  16 G2.5  18 X2.5  18 G2.5  20 X2.5  20 G2.5  2 X4  3 X4  3 G4  4 X4  4 G4  5 X4  5 G4  7 X4  7 G4  9 X4  9 G4  10 X4  10 G4  12 X4  12 G4  2 X6  3 X6  3 G6  4 X6  4 G6  5 X6  5 G6  7 X6  7 G6  9 X6  No. Of  Cores  3  3  4  4  5  5  7  7  9  9  10  10  12  12  14  14  16  16  18  18  20  20  2  3  3  4  4  5  5  7  7  9  9  10  10  12  12  2  3  3  4  4  5  5  7  7  9  Nom. Conductor  Size (mm²)  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  2.5  4  4  4  4  4  4  4  4  4  4  4  4  4  4  4  6  6  6  6  6  6  6  6  6  6  Nom. Cable  Diameter (mm)  11.0  11.0  11.9  11.9  12.9  12.9  14.2  14.2  17.1  17.1  17.8  17.8  18.4  18.4  19.3  19.3  20.3  20.3  21.4  21.4  22.6  22.6  11.9  12.6  12.6  13.9  13.9  15.1  15.1  16.4  16.4  19.9  19.9  20.8  20.8  21.5  21.5  14.0  14.9  14.9  16.2  16.2  17.7  17.7  19.3  19.3  23.5  Nom. Cable Weight  (kg/km)  191  191  233  233  278  278  353  353  459  459  505  505  568  568  641  641  719  719  801  801  873  873  218  268  268  341  341  410  410  514  514  671  671  740  740  839  839  308  384  384  477  477  578  578  731  731  958  4 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.            Technical Data Sheet – Armored (SY) PVC Control Cable Part Code  9G6SY  2X10SY  3X10SY  3G10SY  4X10SY  4G10SY  5X10SY  5G10SY  7X10SY  7G10SY  9X10SY  9G10SY  2X16SY  3X16SY  3G16SY  4X16SY  4G16SY  5X16SY  5G16SY  7X16SY  7G16SY  2X25SY  3X25SY  3G25SY  4X25SY  4G25SY  5X25SY  5G25SY  7X25SY  7G25SY  2X35SY  3X35SY  3G35SY  4X35SY  4G35SY  Cable  Description  9 G6  2 X10  3 X10  3 G10  4 X10  4 G10  5 X10  5 G10  7 X10  7 G10  9 X10  9 G10  2 X16  3 X16  3 G16  4 X16  4 G16  5 X16  5 G16  7 X16  7 G16  2 X25  3 X25  3 G25  4 X25  4 G25  5 X25  5 G25  7 X25  7 G25  2 X35  3 X35  3 G35  4 X35  4 G35    Sheath / Jacket Colour      Colour     1) Grey (RAL 7001)  2) Transparent*    3) Black      4) Blue      5) Orange     6) Violet                     No. Of  Cores  9  2  3  3  4  4  5  5  7  7  9  9  2  3  3  4  4  5  5  7  7  2  3  3  4  4  5  5  7  7  2  3  3  4  4                Nom. Conductor  Size (mm²)  6  10  10  10  10  10  10  10  10  10  10  10  16  16  16  16  16  16  16  16  16  25  25  25  25  25  25  25  25  25  35  35  35  35  35                                            Nom. Cable  Diameter (mm)  23.5  17.0  18.0  18.0  19.8  19.8  21.7  21.7  23.7  23.7  29.1  29.1  20.1  21.4  21.4  23.6  23.6  25.9  25.9  28.4  28.4  24.2  25.9  25.9  28.6  28.6  31.2  31.2  33.9  33.9  27.6  29.5  29.5  32.2  32.2                              Nom. Cable Weight  (kg/km)  958  456  574  574  721  721  878  878  1119  1119  1473  1473  666  851  851  1077  1077  1321  1321  1700  1700  985  1273  1273  1622  1622  1982  1982  2533  2533  1268  1644  1644  2072  2072        Colour Code    G8U    368    010    006    003    007  * Transparent jacket colour by default will have a Grey (RAL 7001) inner jacket colour. For all other colours the inner and outer jacket colour will be the same. Special colours can also be provided upon request.   5 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.            Technical Data Sheet – Armored (SY) PVC Control Cable     Packaging    *Belden can offer these cables with various packing options like coiled, plastic or wooden reels. This  will be decided at the discretion of Belden based on the cable design and structure.       Put‐up Length    Putup Length                    Putup Length Code  1) 100 Meters                    100M  2) 200 Meters*                    200M    3) 300 Meters*                    300M  *Applicable only for certain part codes, please check with Belden for more information.        Stock Code Selection Procedure:      5 X 2 . 5 S Y G X 2 . U 2 Select the sheath / jacket colour code Select the part code from Table A 5 8 5 S Y G 8 0 0 M Select the putup length code U 2 0 0 M Cable Stock Code = 5X2.5SY G8U200M 6 © 2014 Belden, Inc  All Rights Reserved.  Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and  specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages  (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale.
4GDSY-K200 价格&库存
很抱歉,暂时无法提供与“4GDSY-K200”相匹配的价格&库存,您可以联系我们找货
