73407W 008100
73407W 008100
    BELDEN
    CBL 7COND 14AWG
73407W 008100 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 73407W Multi-Conductor - 600V Unshielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 14 AWG stranded (41x30) bare copper conductors, PVC insulation, oil-resistant PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 6 14 41x30 BC - Bare Copper Total Number of Conductors: 7 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 14 Ground Wire Stranding: 41x30 Ground Wire Conductor Material: BC - Bare Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.022 Insulation Color Code Chart: Color Description Black Individually Numbered Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride 0.058 Overall Cable Overall Nominal Diameter: 0.479 in. Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +90°C Installation Temperature Range: Flexing: -5°C To +90°C Bulk Cable Weight: 328 lbs/1000 ft. Max. Recommended Pulling Tension: 225 lbs. Min. Bend Radius/Minor Axis: 2.400 in. Min. Bend/Installation: 2.400 in. Min. Bend Radius (Continuous Flexing): 2.400 in. Flex Cycle Rating: 1 Million Flexes Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs AWM Specification: UL Style 2587 (600 V 90°C) CSA Specification: 600 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes MII Order #39 (China RoHS): Yes Other Specification: VDE 0472, Section 803 Oil Test, EU Low Voltage Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Flame Test Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 73407W Multi-Conductor - 600V Unshielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles CSA Flame Test: FT1 Suitability Suitability - Burial: Yes Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/ft) 0.170 Max. Capacitance Conductor to Conductor: Freq. (MHz) Capacitance (pF/ft) 0.001 36.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.600 Max. Operating Voltage - UL: Voltage 600V Put Ups and Colors: Item # Putup Ship Weight Color 73407W 008100 100 FT 37.500 LB GRAY 14AWG 41/30 7C UNSHIELDED 73407W 008500 500 FT 178.000 LB GRAY 14AWG 41/30 7C UNSHIELDED Revision Number: 0 Notes Item Desc Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
73407W 008100 价格&库存
很抱歉,暂时无法提供与“73407W 008100”相匹配的价格&库存,您可以联系我们找货
