73803WS 0081000
73803WS 0081000
    BELDEN
    3 芯 多芯 线缆 灰色 18AWG 编织线 1000.0'(304.8m)
73803WS 0081000 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 73803WS Multi-Conductor - 600V Shielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) bare copper conductors, PVC insulation, oil-resistant PVC inner jacket, tinned copper braid shield, 85% coverage, oil-resistant overall PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material Dia. (mm) 2 18 16x30 BC - Bare Copper 1.194 Total Number of Conductors: 3 Ground Wire Ground Wire (Y/N): Y Ground Wire AWG: 18 Ground Wire Stranding: 16X30 Ground Wire Conductor Material: BC - Bare Copper Ground Wire Insulation Material: PVC - Polyvinyl Chloride Insulation Insulation Material: Insulation Material Wall Thickness (mm) Dia. (mm) PVC - Polyvinyl Chloride 0.559 2.311 Insulation Color Code Chart: Color Description Black Individually Numbered Yellow/Green Ground Inner Jacket Inner Jacket Material: Inner Jacket Material Nom Wall (mm) Nom. Dia. (mm) PVC - Polyvinyl Chloride 0.762 6.655 Outer Shield Outer Shield Material: Outer Shield Material Coverage (%) TC - Tinned Copper 85.000 Outer Shield Separator Material: Tissue Tape, 25% Overlap, Min. Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (mm) PVC - Polyvinyl Chloride 0.889 Overall Cable Overall Nominal Diameter: 9.144 mm Mechanical Characteristics (Overall) Storage Temperature Range: -40°C To +90°C Installation Temperature Range: Flexing: -5°C To +90°C Operating Temperature Range: Flexing: -5°C To +90°C Bulk Cable Weight: 236.624 Kg/Km Max. Recommended Pulling Tension: 195.721 N Min. Bend Radius/Minor Axis: 45.720 mm Min. Bend/Installation: 45.720 mm Min. Bend Radius (Continuous Flexing): 45.720 mm Flex Cycle Rating: 1 Million Flexes Page 1 of 2 10-02-2017 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 73803WS Multi-Conductor - 600V Shielded, Light to Moderate Flexing Applications Up to 1 Million Flex Life Cycles Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: THHN/THWN Singles AWM Specification: UL Style 2587 (600 V 90°C) CSA Specification: 600 V AWM I/II A/B EU Directive 2011/65/EU (ROHS II): Yes Other Specification: AWM/STYLE 2587, AWM I/II A/B, FT1, VDE 0472, Section 803 Oil Test, EU Low Voltage Directive 2014/35/EC, EU Directive 2011/65/EU(RoHS2), REACH Regulation (EC 1907/2006), California Proposition 65 Flame Test CSA Flame Test: FT1 Electrical Characteristics (Overall) Nom. Inductance: Inductance (µH/m) 0.689 Nom. Capacitance Cond. to Other Cond. & Ground: Description Freq. (kHz) Capacitance (pF/m) Nom. Cond. to Cond 1.000 124.678 Nom. Ground. 223.108 1.000 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 34.779 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 11.484 Put Ups and Colors: Item # Putup Ship Weight Color 73803WS 008100 100 FT 19.400 LB GRAY Notes Item Desc 18AWG 19/30 3C SHIELDED 73803WS 0081000 1,000 FT 164.000 LB GRAY 18AWG 19/30 3C SHIELDED 73803WS 008500 500 FT 84.000 LB GRAY 18AWG 19/30 3C SHIELDED Revision Number: 0 Revision Date: 09-27-2017 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Page 2 of 2 10-02-2017
73803WS 0081000 价格&库存
很抱歉,暂时无法提供与“73803WS 0081000”相匹配的价格&库存,您可以联系我们找货
73803WS 0081000
  • 1+46.746211+5.86433
  • 5+41.771375+5.24023
  • 10+39.7797410+4.99038
  • 25+37.2739225+4.67603
  • 50+35.4683550+4.44952
  • 100+33.73698100+4.23232
库存:700
