74003PU
74003PU
    BELDEN
    BELDEN - 74003PU - Networking Cable, Screened, Cat5e, 26 AWG, 1000 ft, 304.8 m
74003PU 数据手册
Industrial Ethernet Cables SF/UTP Cat 5e – 4 Pair Cables A range of shielded copper cables for use in industrial Ethernet networks, designed to withstand the entire spectrum of environmental and mechanical hazards, from temperature extremes and sunlight, to solvents, oils, chemicals and moisture. Ordering Information Belden European Item Numbers Jacket Material PVC Premium FRNC PUR (Halogen Free) Performance Cat 5e Cat 5e Cat 5e Number of Pairs 4 Pairs 4 Pairs 4 Pairs Stationary Application 74001E 74001NH 74001PU Flexible Application ication Appl 74002E 74002NH 74002PU Highly Flexible Application 74003PU Applications • • • • • Industrial environments where IP67 may be required Transmission of data in industrial applications via the ethernet protocol Stationary applications, where there is no movement after installation Flexible applications, subject to occasional movement or vibration after installation Highly flexible, trailing applications, for instance ‘C Track’ Features & Benefits • Choice of PVC, Premium FRNC or PUR cable jacket for specific application requirements in the harsh industrial environment • High shield coverage to maintain signal integrity in the industrial ‘noisy’ environment • Oil resistant • Chemical & solvent resistant • Temperature resistant • Abrasion resistant • Excellent mechanical resistance • Weld-splatter resistant PUR cable jacket available on request • IP67 rated • UV resistant • Black cable jacket Construction & Dimensions Mechanical Data – Stationary Application Conductor (24AWG/1 - Solid Bare Copper) 2 Twisted, Polypropylene Insulated Conductors - Pair 1 = White / Blue - Pair 2 = White / Orange - Pair 3 = White / Green - Pair 4 = White / Brown Foil Shield – Laminated Aluminium / Polyester Braid Shield – Tinned Copper Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) Sheath Colour 74001E 24AWG/1 1.10mm >80% PVC 7.00mm Black 74001NH 24AWG/1 1.10mm >80% FRNC 7.00mm Black 74001PU 24AWG/1 1.10mm >80% PUR 6.60mm Black Part Number Mechanical Data – Flexible Application Conductor (26AWG/7 – 7x0.16mm Stranded Tinned Copper) 2 Twisted, Polypropylene Insulated Conductors - Pair 1 = White / Blue - Pair 2 = White / Orange - Pair 3 = White / Green - Pair 4 = White / Brown Foil Shield – Laminated Aluminium / Polyester Braid Shield – Tinned Copper Part Number Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath (Nom. Dia.) Sheath Colour 74002E 26AWG/7 0.98mm >80% PVC 6.50mm Black 74002NH 26AWG/7 0.98mm >80% FRNC 6.50mm Black 74002PU 26AWG/7 0.98mm >80% PUR 6.50mm Black 2 Mechanical Data – Highly Flexible Application Conductor (26AWG/19 – 19x0.1mm Stranded Tinned Cu) 2 Twisted, Polypropylene Insulated Conductors - Pair 1 = White / Blue - Pair 2 = White / Orange - Pair 3 = White / Green - Pair 4 = White / Brown Foil Shield – Laminated Aluminium / Polyester Braid Shield – Tinned Copper Part Number Conductor Insulation (Nom. Dia.) Braid Coverage Sheath Material Sheath Sheath (Nom. Dia.) Sheath Colour 74003PU 26AWG/19 1.00mm >80% PUR 6.65mm Black Standards • ISO/IEC 11801 2 • ISO/IEC 24702 • EN 50173-1 • TIA/EIA-568-B.2 nd Edition Electrical Properties 450V A.C. / 300V D.C. 68% < 5.34 ns / m 100 +/- 15 Ohm Max Operating Voltage UL Velocity of Propagation @ 4 – 100 MHz Delay Impedance @ 1 – 100 MHz 74001E / 74001NH / 74001PU (AWG24) Frequency (MHz) 1 4 10 16 20 25 31.25 62.5 100 Insertion Loss (Max) (dB/100m) 2.0 4.1 6.5 8.2 9.3 10.4 11.7 17.0 22.0 NEXT (dB) 65.3 56.3 50.3 47.2 45.8 44.3 42.9 38.3 35.3 ELFEXT (dB/100m) 63.8 51.7 43.8 39.7 37.7 35.8 33.9 27.8 23.8 RETURN RETURN LOSS (dB) 20.0 23.0 25.0 25.0 25.0 24.3 23.6 21.5 20.1 3 74002E / 74002NH / 74002PU / 74003PU (AWG26) Frequency (MHz) 1 4 10 16 20 25 31.25 62.5 100 Insertion Loss (Max) (dB/100m) 3.2 6.0 9.5 12.1 13.6 15.3 17.1 24.8 32 NEXT (dB) 65.3 56.3 50.3 47.2 45.8 44.3 42.9 38.3 35.3 ELFEXT (dB/100m) 63.8 51.7 43.8 39.7 37.7 35.8 33.9 27.8 23.8 RETURN LOSS (dB) 20.0 23.0 25.0 25.0 25.0 24.3 23.6 21.5 20.1 Mechanical, Physical and/or Environmental Characteristics Flame Resistance Oil Resistance Bending Radius / Setting Radius IEC 60332-1 IEC 60811-2-1 10 x Diameter / 5 x Diameter Halogen Free Maximum Pulling Tension Temperature Range - Installation Temperature Range - Operating IEC 60754-1 / IEC 60754-2 (FRNC and PUR Cable) 80N -5.0oC to +50.0oC -40.0oC to +80.0oC Version 03 (07/10) 4
74003PU
物料型号:文档列出了几种不同型号的电缆,包括74001E、74001NH、74001PU、74002E、74002NH、74002PU和74003PU。
器件简介:这些电缆是为工业以太网网络设计的屏蔽铜缆,能够承受极端温度、阳光、溶剂、油脂、化学物质和湿度等环境和机械危害。
引脚分配:电缆由4对24AWG/1或26AWG/7的导体组成,每对导体由聚丙烯绝缘,颜色编码为白/蓝、白/橙、白/绿和白/棕。
参数特性:电缆具有多种特性,包括高屏蔽覆盖率、耐油、耐化学和溶剂、耐温、耐磨损、抗焊渣的PUR电缆外皮(按需提供)、IP67等级和抗紫外线。
功能详解:电缆适用于可能需要IP67等级的工业环境、通过以太网协议传输数据的工业应用、安装后无移动的固定应用、安装后偶尔移动或振动的柔性应用以及高度柔性的拖曳应用。
应用信息:适用于需要IP67等级的工业环境、工业应用中的数据传输、固定应用、柔性应用和高度柔性的拖曳应用。
封装信息:电缆有PVC、高级FRNC或PUR电缆外皮的选择,以满足特定工业环境的应用要求。外皮颜色为黑色。
74003PU 价格&库存
很抱歉,暂时无法提供与“74003PU”相匹配的价格&库存,您可以联系我们找货
