8240 010U500
8240 010U500
    BELDEN
    #20 PE BRD FRPVC
8240 010U500 数据手册
Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8240 Coax - RG-58A/U Type For more Information please call 1-800-Belden1 Description: RG-58A/U type, 20 AWG solid .033" bare copper conductor, polyethylene insulation, tinned copper braid shield (95% coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material Dia. (mm) 1 20 Solid BC - Bare Copper 0.8382 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Dia. (mm) PE - Polyethylene 2.9464 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid TC - Tinned Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 4.902 mm Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +75°C UL Temperature Rating: 80°C (UL AWM Style 1354) Bulk Cable Weight: 38.693 Kg/Km Max. Recommended Pulling Tension: 209.065 N Min. Bend Radius/Minor Axis: 50.800 mm Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMX CEC/C(UL) Specification: CMX AWM Specification: UL Style 1354 (30 V 80°C) EU CE Mark: No EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 Page 1 of 3 11-14-2012 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8240 Coax - RG-58A/U Type EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 58/U Flame Test UL Flame Test: UL1685 UL Loading, VW-1 Suitability Suitability - Indoor: Yes Suitability - Outdoor: Yes Suitability - Aerial: Yes - when supported by a messenger wire Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88240, 82240 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 52 Nom. Inductance: Inductance (µH/m) 0.26248 Nom. Capacitance Conductor to Shield: Capacitance (pF/m) 93.5085 Nominal Velocity of Propagation: VP (%) 66 Nominal Delay: Delay (ns/m) 5.05274 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/km) 32.81 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/km) 13.4521 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100m) 1 0.9843 10 3.6091 50 8.2025 100 12.4678 200 18.3736 400 27.5604 700 38.3877 900 44.9497 1000 47.5745 Max. Power Rating: Freq. (MHz) Rating (W) 50 530 Page 2 of 3 11-14-2012 Detailed Specifications & Technical Data METRIC MEASUREMENT VERSION 8240 Coax - RG-58A/U Type 100 350 400 160 1000 90 Max. Operating Voltage - UL: Voltage 300 V RMS (CMX) 30 V RMS (UL AWM Style 1354) Max. Operating Voltage - Non-UL: Voltage 1400 V RMS Other Electrical Characteristic 1: Actual Impedance specification is 51.5 +/- 1.5 ohms. Put Ups and Colors: Item # Putup Ship Weight Color 8240 010U1000 305 MT 12.247 KG BLACK Notes Item Desc #20 PE BRD FRPVC 8240 010U500 152 MT 6.350 KG BLACK #20 PE BRD FRPVC 8240 010100 30 MT 1.497 KG BLACK 8240 0101000 305 MT 12.247 KG BLACK C #20 PE BRD FRPVC 8240 010500 152 MT 6.577 KG BLACK C #20 PE BRD FRPVC 8240 0105000 1,524 MT 61.235 KG BLACK C #20 PE BRD FRPVC #20 PE BRD FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 08-09-2012 © 2012 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Page 3 of 3 11-14-2012
8240 010U500 价格&库存
很抱歉,暂时无法提供与“8240 010U500”相匹配的价格&库存,您可以联系我们找货
