Detailed Specifications & Technical Data
ENGLISH MEASUREMENT VERSION
82444 Multi-Conductor - Audio, Control and Instrumentation Cable
For more Information
please call
1-800-Belden1
General Description:
22 AWG stranded (7x30) TC conductors, conductors cabled, plenum, FEP insulation, natural Flamarrest®
jacket.
Physical Characteristics (Overall)
Conductor
AWG:
# Conductors AWG Stranding Conductor Material
4
22
7x30
TC - Tinned Copper
Total Number of Conductors:
4
Insulation
Insulation Material:
Insulation Material
Wall Thickness (in.)
FEP - Fluorinated Ethylene Propylene 0.007
Outer Shield
Outer Shield Material:
Unshielded
Outer Jacket
Outer Jacket Material:
Outer Jacket Trade Name Outer Jacket Material
Flamarrest®
Nom. Wall Thickness (in.)
LS PVC - Low Smoke Polyvinyl Chloride .015
Overall Cable
Overall Cabling Color Code Chart:
Number Color
1
Black
2
White
3
Red
4
Green
Overall Nominal Diameter:
0.134 in.
Mechanical Characteristics (Overall)
Operating Temperature Range:
0°C To +60°C
Bulk Cable Weight:
15 lbs/1000 ft.
Max. Recommended Pulling Tension:
36 lbs.
Min. Bend Radius/Minor Axis:
1.500 in.
Applicable Specifications and Agency Compliance (Overall)
Applicable Standards & Environmental Programs
NEC/(UL) Specification:
CMP
CEC/C(UL) Specification:
CMP
EU Directive 2011/65/EU (ROHS II):
Yes
EU CE Mark:
Yes
EU Directive 2000/53/EC (ELV):
Yes
EU Directive 2002/95/EC (RoHS):
Yes
EU RoHS Compliance Date (mm/dd/yyyy):
04/01/2005
EU Directive 2002/96/EC (WEEE):
Yes
EU Directive 2003/11/EC (BFR):
Yes
CA Prop 65 (CJ for Wire & Cable):
Yes
Page 1 of 2
08-26-2016
MII Order #39 (China RoHS):
Yes
Flame Test
UL Flame Test:
NFPA 262
CSA Flame Test:
FT6
Plenum/Non-Plenum
Plenum (Y/N):
Yes
Non-Plenum Number:
8444
Electrical Characteristics (Overall)
Nom. Capacitance Conductor to Conductor:
Capacitance (pF/ft)
18
Nom. Conductor DC Resistance:
DCR @ 20°C (Ohm/1000 ft)
15
Nominal Conductor Loop Resistance:
Resistance @ 20°C (Ohm/1000 ft)
30
Max. Operating Voltage - UL:
Voltage
300 V RMS
Max. Recommended Current:
Current
3.3 Amps per conductor @ 25°C (10°C rise in temp)
Put Ups and Colors:
Item #
Putup
Ship Weight
Color
82444 877U1000
1,000 FT
16.000 LB
NATURAL
82444 877U500
500 FT
8.500 LB
NATURAL
82444 8771000
1,000 FT
16.000 LB
NATURAL
Notes
Item Desc
4C #22 FEP FLMRST
4C#22 FEP FLMRST
C
4C#22 FEP FLMRST
Notes:
C = CRATE REEL PUT-UP.
Revision Number: 2
Revision Date: 08-31-2012
© 2016 Belden, Inc
All Rights Reserved.
Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to
change without notice, and the listing of such information and specifications does not ensure product availability.
Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for
any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether
in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein.
All sales of Belden products are subject to Belden's standard terms and conditions of sale.
Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities
and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is
correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the
safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification.
Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the
product.
Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU).
Page 2 of 2
08-26-2016
很抱歉,暂时无法提供与“82444 877U1000”相匹配的价格&库存,您可以联系我们找货
