8255 010500
8255 010500
    BELDEN
    COAX RG-62/U JAN-C-17A
8255 010500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8255 Coax - 93 Ohm For more Information please call 1-800-Belden1 General Description: 93 ohm, RG-62B/U type, 24 AWG stranded (7x32) .024" bare copper-covered steel conductor, semi-solid polyethylene insulation, BC braid shield (95% coverage), non-contaminating PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Coax AWG Stranding Conductor Material 1 24 7x32 Dia. (in.) BCCS - Bare Copper Covered Steel .024 Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) Dia. (in.) Semi-Solid PE - Semi-Solid Polyethylene 0.026 0.146 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Braid BC - Bare Copper 95 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVCNC - Polyvinyl Chloride Non-Contaminating 0.033 Overall Cable Overall Nominal Diameter: 0.242 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C UL Temperature Rating: 60°C (UL AWM Style 1354) Bulk Cable Weight: 32 lbs/1000 ft. Max. Recommended Pulling Tension: 75 lbs. Min. Bend Radius/Minor Axis: 2.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMX CEC/C(UL) Specification: CMX AWM Specification: UL Style 1354 (30 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes RG Type: 62B/U Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8255 Coax - 93 Ohm Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 93 Nom. Inductance: Inductance (µH/ft) 0.116 Nom. Capacitance Conductor to Shield: Capacitance (pF/ft) 13.5 Nominal Velocity of Propagation: VP (%) 84 Nominal Delay: Delay (ns/ft) 1.21 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 59.0 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 2.9 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.3 10 0.9 50 2.0 100 2.9 200 4.2 400 6.1 700 8.6 900 10.1 1000 11.1 Max. Operating Voltage - UL: Voltage Description 30 V RMS UL AWM Style 1354 300 V RMS CMX Max. Operating Voltage - Non-UL: Voltage 750 V RMS Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8255 0101000 1,000 FT 36.000 LB BLACK C RG-62B/U TYPE 93OHM COAX 8255 010500 500 FT 18.500 LB BLACK RG-62B/U TYPE 93OHM COAX Notes: C = CRATE REEL PUT-UP. Revision Number: 2 Revision Date: 10-16-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8255 Coax - 93 Ohm Page 3 of 3 01-05-2017
8255 010500 价格&库存
很抱歉,暂时无法提供与“8255 010500”相匹配的价格&库存,您可以联系我们找货
