83005 0011000
83005 0011000
    BELDEN
    HOOK-UP STRND 22AWG BROWN 1000
83005 0011000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83005 Hook-up/Lead - UL AWM Style 1213 For more Information please call 1-800-Belden1 General Description: Stranded silver-coated copper conductor insulation with extruded TFE Teflon. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 22 7x30 SPC - Silver Plated Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) TFE - Tetrafluoroethylene .010 Overall Insulation Overall Cable Overall Nominal Diameter: 0.050 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 4 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 105°C EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: NEMA HP3, MIL-W-16878/4 MIL Spec Rating: 600 V, 200°C Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 15.250 Max. Operating Voltage - Other: Voltage Description 600 VRMS Mil-W-16878/4 Max. Recommended Current: Description Current Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83005 Hook-up/Lead - UL AWM Style 1213 Mil-Std-975M Table 3.16 (single wire) 4.5 amps Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 83005 001100 100 FT 0.400 LB BROWN E #22 STR TFE BRN 83005 0011000 1,000 FT 4.000 LB BROWN ES #22 STR TFE BRN 83005 002100 100 FT 0.400 LB RED E #22 STR TFE RED 83005 0021000 1,000 FT 4.000 LB RED ES #22 STR TFE RED 83005 003100 100 FT 0.400 LB ORANGE E #22 STR TFE ORG 83005 0031000 1,000 FT 4.000 LB ORANGE ES #22 STR TFE ORG 83005 004100 100 FT 0.400 LB YELLOW E #22 STR TFE YEL 83005 0041000 1,000 FT 4.000 LB YELLOW ES #22 STR TFE YEL 83005 005100 100 FT 0.400 LB GREEN, DARK E #22 STR TFE GRNDK 83005 0051000 1,000 FT 4.000 LB GREEN, DARK ES #22 STR TFE GRNDK 83005 006100 100 FT 0.400 LB BLUE, LIGHT E #22 STR TFE BLULT 83005 0061000 1,000 FT 4.000 LB BLUE, LIGHT ES #22 STR TFE BLULT 83005 007100 100 FT 0.400 LB VIOLET E #22 STR TFE VIO 83005 0071000 1,000 FT 4.000 LB VIOLET ES #22 STR TFE VIO 83005 008100 100 FT 0.400 LB GRAY E #22 STR TFE GRY 83005 0081000 1,000 FT 4.000 LB GRAY ES #22 STR TFE GRY 83005 009100 100 FT 0.400 LB WHITE E #22 STR TFE WHT 83005 0091000 1,000 FT 4.000 LB WHITE ES #22 STR TFE WHT 83005 010100 100 FT 0.400 LB BLACK E #22 STR TFE BLK 83005 0101000 1,000 FT 4.000 LB BLACK #22 STR TFE BLK Notes: E = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 25' S = STRIPING ADDERS FOR TYPES E AND EE: 123 STRIPES. MINIMUM ORDER10 Revision Number: 2 Revision Date: 08-30-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
83005 0011000 价格&库存
很抱歉,暂时无法提供与“83005 0011000”相匹配的价格&库存,您可以联系我们找货
