83030 0091000
83030 0091000
    BELDEN
    HOOK-UP 16AWG STR WHT
83030 0091000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83030 Hook-up/Lead - UL AWM Style 1180 For more Information please call 1-800-Belden1 General Description: Stranded silver-coated copper conductor insulatioin with extruded TFE Teflon. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 16 19x29 SPC - Silver Plated Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) TFE - Tetrafluoroethylene .015 Overall Insulation Overall Cable Overall Nominal Diameter: 0.088 in. Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Bulk Cable Weight: 11 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs UL Rating: 300 V RMS, 200°C EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: NEMA HP3, MIL-W-16878/5 (Except For Stranding) MIL Spec Rating: 1000 V, 200°C Flame Test UL Flame Test: VW-1 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 4.000 Max. Operating Voltage - UL: Voltage Description 300V RMS UL AWM 1180 Max. Operating Voltage - Other: Voltage Description Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83030 Hook-up/Lead - UL AWM Style 1180 1000V RMS Mil-W-16878/5 Max. Recommended Current: Description Current Mil-Std-975M Table 3.16 (single wire) 13 amps Put Ups and Colors: Item # Putup Ship Weight Color 83030 001100 100 FT 1.300 LB BROWN Notes Item Desc 83030 0011000 1,000 FT 12.000 LB BROWN 83030 002100 100 FT 1.300 LB RED 83030 0021000 1,000 FT 12.000 LB RED 83030 003100 100 FT 1.300 LB ORANGE 83030 0031000 1,000 FT 12.000 LB ORANGE 83030 004100 100 FT 1.300 LB YELLOW 83030 0041000 1,000 FT 12.000 LB YELLOW 83030 005100 100 FT 1.300 LB GREEN, DARK 83030 0051000 1,000 FT 12.000 LB GREEN, DARK 83030 006100 100 FT 1.300 LB BLUE, LIGHT 83030 0061000 1,000 FT 12.000 LB BLUE, LIGHT 83030 007100 100 FT 1.300 LB VIOLET 83030 0071000 1,000 FT 12.000 LB VIOLET 83030 008100 100 FT 1.300 LB GRAY 83030 0081000 1,000 FT 12.000 LB GRAY 83030 009100 100 FT 1.300 LB WHITE 83030 0091000 1,000 FT 12.000 LB WHITE SW #16 STR TFE WHT 83030 009500 500 FT 6.000 LB WHITE SW #16 STR TFE WHT 83030 010100 100 FT 1.300 LB BLACK 83030 0101000 1,000 FT 12.000 LB BLACK SW #16 STR TFE BLK 83030 010500 500 FT 6.000 LB BLACK SW #16 STR TFE BLK #16 STR TFE BRN SW #16 STR TFE BRN #16 STR TFE RED SW #16 STR TFE RED #16 STR TFE ORG SW #16 STR TFE ORG #16 STR TFE YEL SW #16 STR TFE YEL #16 STR TFE GRNDK SW #16 STR TFE GRNDK #16 STR TFE BLULT SW #16 STR TFE BLULT #16 STR TFE VIO SW #16 STR TFE VIO #16 STR TFE GRY SW #16 STR TFE GRY #16 STR TFE WHT #16 STR TFE BLK Notes: S = STRIPING ADDERS FOR TYPES E AND EE: 123 STRIPES. MINIMUM ORDER10 W = MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 75' Revision Number: 2 Revision Date: 08-30-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
83030 0091000 价格&库存
很抱歉,暂时无法提供与“83030 0091000”相匹配的价格&库存,您可以联系我们找货
  • 305+46.42964305+5.95510
  • 610+40.17442610+5.15280
