83953 004500
    BELDEN
    THERMOCOUPLE TYPE KX 16AWG
83953 004500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83953 Multi-Conductor - High-Temperature Thermocouple Extension Cable For more Information please call 1-800-Belden1 General Description: 16 AWG pairs stranded (7x24) conductors, overall Beldfoil shield (100% coverage), FEP insulation, FEP jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 16 7x24 Chromel & Alumel Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) FEP - Fluorinated Ethylene Propylene .010 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 18 7x26 TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material FEP - Fluorinated Ethylene Propylene Overall Cable Overall Nominal Diameter: 0.187 in. Pair Pair Color Code Chart: Number Color 1 Yellow & Red Mechanical Characteristics (Overall) Operating Temperature Range: -70°C To +200°C Non-UL Temperature Rating: 200°C Bulk Cable Weight: 36 lbs/1000 ft. Min. Bend Radius/Minor Axis: 2 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: PLTC, CL3P EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 83953 Multi-Conductor - High-Temperature Thermocouple Extension Cable MII Order #39 (China RoHS): Yes ANSI Specification: MC 96.1-1982 Type KX Flame Test UL Flame Test: UL910 Steiner Tunnel Plenum/Non-Plenum Plenum (Y/N): Yes Surface Printing (Overall) Electrical Characteristics (Overall) Nom. Conductor DC Resistance: Description DCR @ 20°C (Ohm/1000 ft) CHROMEL 154 ALUMEL 62 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.6 Notes (Overall) Notes: Chromel & Alumel = "Chromel and Alumel are Hoskins Manufacturing Company trademarks." Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 83953 0041000 1,000 FT 34.000 LB YELLOW C 2#16TYPE KX THERMOCOUPLE 83953 004500 500 FT 18.000 LB YELLOW C 2#16TYPE KX THERMOCOUPLE Notes: C = CRATE REEL PUT-UP. Revision Number: 1 Revision Date: 05-14-2007 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
83953 004500 价格&库存
很抱歉,暂时无法提供与“83953 004500”相匹配的价格&库存,您可以联系我们找货
