8471NH.00305
8471NH.00305
    BELDEN
    BELDEN - 8471NH.00305 - Multipair Cable, Audio Control, Unscreened, 1 Pair, 16 AWG, 1.3 mm², 1000 ft...
8471NH.00305 数据手册
Product datasheet page 1 of 1 date 16/11/00 8471NH Description 16 AWG (19*29) tinned copper , Pe insulated, 1 twisted pair,PET foil, Unshielded, LSNH Jacket Dimensions Nom. insulation Thickness 0.56 mm Nom. diameter over insulation 2.67 mm Nom. Jacket thickness 0.89 mm Nom. outer diameter 7.15 mm Max. operating voltage 300 V Rms Max. Continuos current per conductor @ 25 deg. C 7.1 A pb nF/km 14.7 Ohm/km pb % Temperature rating -15 to +80 Deg. C Insulation material Pe Electrical characteristics Nom. Capacitance between conductors of a pair @ 1kHz Nom. Conductor DC resistance @ 20 Deg. C Velocity of propagation Physical characteristics Jacket material (color) Type shield and % coverage LSNH (Chrome RAL 7037) unshielded Max. pulling tension 250 N Min. bend radius 130 mm Applicable specifications Flame resistance BS 7655 Section 6.1 Table 1 LTS 3 IEC 332-1 Color code Black & White Application Instrumentation and computer cables for Data transmission Applications (Label contains Ce marking) feb 00 JZ © Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
8471NH.00305 价格&库存
很抱歉,暂时无法提供与“8471NH.00305”相匹配的价格&库存,您可以联系我们找货
8471NH.00305
  • 1+8706.09274
库存:1520
