8500 0171000
8500 0171000
    BELDEN
    HOOK-UP 16AWG STR WHT/YEL
8500 0171000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8500 Hook-up/Lead - (Type B) MIL-W-16878/1-PVC For more Information please call 1-800-Belden1 General Description: Tinned copper conductor, PVC insulation. Covers insulated wire for internal wiring of meters, panels, and electrical or electronic equipment. Temperatures to 105ºC. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 16 19x29 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .010 Overall Insulation Overall Cable Overall Nominal Diameter: 0.079 in. Mechanical Characteristics (Overall) Bulk Cable Weight: 10 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2006 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-16878/1 MIL Spec Rating: 600 V, 105°C Plenum/Non-Plenum Plenum (Y/N): No Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 8500 0011000 1,000 FT 10.000 LB BROWN P 16 STR PVC BRN 8500 002100 100 FT 1.100 LB RED 8500 0021000 1,000 FT 10.000 LB RED P 16 STR PVC RED 8500 0031000 1,000 FT 10.000 LB ORANGE P 16 STR PVC ORG 8500 004100 100 FT 1.100 LB YELLOW 8500 0041000 1,000 FT 10.000 LB YELLOW 8500 005100 100 FT 1.100 LB GREEN, DARK 8500 0051000 1,000 FT 10.000 LB GREEN, DARK 8500 006100 100 FT 1.100 LB BLUE, LIGHT 8500 0061000 1,000 FT 10.000 LB BLUE, LIGHT P 16 STR PVC LBLU 8500 0071000 1,000 FT 10.000 LB VIOLET P 16 STR PVC VIO 16 STR PVC RED Page 1 of 2 16 STR PVC YEL P 16 STR PVC YEL 16 STR PVC GRN P 16 STR PVC GRN 16 STR PVC LBLU 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8500 Hook-up/Lead - (Type B) MIL-W-16878/1-PVC 8500 0081000 1,000 FT 10.000 LB GRAY 8500 009100 100 FT 1.100 LB WHITE P 16 STR PVC GRY 8500 0091000 1,000 FT 10.000 LB WHITE 8500 010100 100 FT 1.100 LB BLACK 8500 0101000 1,000 FT 10.000 LB BLACK P 16 STR PVC BLK 8500 0141000 1,000 FT 10.000 LB WHITE/BLACK A 16 STR PVC WHT/BLK 8500 0151000 1,000 FT 10.000 LB WHITE/RED A 16 STR PVC WHT/RED 8500 0161000 1,000 FT 10.000 LB WHITE/GREEN A 16 STR PVC WHT/GRN 8500 0171000 1,000 FT 10.000 LB WHITE/YELLOW A 16 STR PVC WHT/YEL 8500 0181000 1,000 FT 10.000 LB WHITE/BLUE A 16 STR PVC WHT/BLU 8500 0191000 1,000 FT 10.000 LB WHITE/BROWN A 16 STR PVC WHT/BRN 8500 0201000 1,000 FT 10.000 LB WHITE/ORANGE A 16 STR PVC WHT/ORG 16 STR PVC WHT P 16 STR PVC WHT 16 STR PVC BLK Notes: A = STOCKED STRIPE COLORS. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 2 Revision Date: 11-07-2014 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8500 0171000 价格&库存
很抱歉,暂时无法提供与“8500 0171000”相匹配的价格&库存,您可以联系我们找货
  • 305+16.60543305+2.15830
  • 610+14.43194610+1.87580
