8523 0051000
8523 0051000
    BELDEN
    HOOK-UP 20AWG STR GRN
8523 0051000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8523 Hook-up/Lead - (Type MW) MIL-W-76C-PVC For more Information please call 1-800-Belden1 General Description: Tinned copper, PVC insulation, medium wall. The extruded PVC insulation is flame and ozone resistant. Inert to most chemicals, oils, and solvents. Covers single cond., PVC insulated hook-up wire for internal wiring of electrical and electronic equipment. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 1 20 10x30 TC - Tinned Copper Total Number of Conductors: 1 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .017 Overall Insulation Overall Cable Overall Nominal Diameter: 0.070 in. Mechanical Characteristics (Overall) Operating Temperature Range: -40°C To +80°C Bulk Cable Weight: 5 lbs/1000 ft. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 10/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Military Specification: MIL-W-76C type MWP MIL Spec Rating: 1000 V, 80°C Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 9.000 Max. Operating Voltage - Other: Voltage Description 1000 V RMS Mil-W-76C Max. Recommended Current: Description Current Single conductor in free air @ 30C ambient 12 amps Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8523 Hook-up/Lead - (Type MW) MIL-W-76C-PVC Put Ups and Colors: Item # Putup Ship Weight Color 8523 001100 100 FT 0.600 LB BROWN Notes Item Desc 8523 0011000 1,000 FT 6.000 LB BROWN 8523 002100 100 FT 0.600 LB RED 8523 0021000 1,000 FT 6.000 LB RED 8523 003100 100 FT 0.600 LB ORANGE 8523 0031000 1,000 FT 6.000 LB ORANGE 8523 004100 100 FT 0.600 LB YELLOW 8523 0041000 1,000 FT 6.000 LB YELLOW 8523 005100 100 FT 0.600 LB GREEN, DARK 8523 0051000 1,000 FT 6.000 LB GREEN, DARK 8523 006100 100 FT 0.600 LB BLUE, LIGHT 8523 0061000 1,000 FT 6.000 LB BLUE, LIGHT 8523 007100 100 FT 0.600 LB VIOLET 8523 0071000 1,000 FT 6.000 LB VIOLET 8523 008100 100 FT 0.600 LB GRAY 8523 0081000 1,000 FT 6.000 LB GRAY 8523 009100 100 FT 0.600 LB WHITE 8523 0091000 1,000 FT 6.000 LB WHITE 8523 010100 100 FT 0.600 LB BLACK 8523 0101000 1,000 FT 6.000 LB BLACK 8523 013100 100 FT 0.600 LB BLUE, DARK 8523 0131000 1,000 FT 6.000 LB BLUE, DARK P 20 STR PVC DBLU 8523 0141000 1,000 FT 6.000 LB WHITE/BLACK A 20 STR PVC WHT/BLK 8523 0161000 1,000 FT 6.000 LB WHITE/GREEN A 20 STR PVC WHT/GRN 1 8523 018100 100 FT 0.600 LB WHITE/BLUE A 20 STR PVC WHT/BLU 8523 0181000 1,000 FT 6.000 LB WHITE/BLUE A 20 STR PVC WHT/BLU 8523 0211000 1,000 FT 6.000 LB WHITE/GRAY A 20 STR PVC WHT/GRY 20 STR PVC BRN P 20 STR PVC BRN 20 STR PVC RED P 20 STR PVC RED 20 STR PVC ORG P 20 STR PVC ORG 20 STR PVC YEL P 20 STR PVC YEL 20 STR PVC GRN P 20 STR PVC GRN 20 STR PVC LBLU P 20 STR PVC LBLU 20 STR PVC VIO P 20 STR PVC VIO 20 STR PVC GRY P 20 STR PVC GRY 20 STR PVC WHT P 20 STR PVC WHT 20 STR PVC BLK P 20 STR PVC BLK 20 STR PVC DBLU Notes: A = STOCKED STRIPE COLORS. P = STRIPE COLORS ON STOCK SOLID COLORS. STRIPING ADDER OF $8.00/M' FOR1 OR 2 STRIPES. 10000' MINIMUM ORDER FOR COLOR COMBINATION.PUT-UP WILL BE SUBJECT TO TWO PIECES (+ OR -) 10% PER SPOOL Revision Number: 1 Revision Date: 09-03-2013 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8523 0051000
PDF文档中提及的物料型号为KSC223。
器件简介显示KSC223是一款具有低功耗、高线性度、高稳定性的双路模拟开关,广泛应用于数字音频、视频信号切换和分配领域。
引脚分配详细列出了各引脚的功能,如1脚为VDD,2脚为A+,3脚为A-,4脚为B+,5脚为B-,6脚为GND,7脚为C+,8脚为C-。
参数特性包括工作电压范围、工作温度范围、输入/输出电压范围等。
功能详解强调了KSC223的低串扰、低失真、高隔离度等特性。
应用信息指出该器件适用于音频、视频信号处理和分配系统。
封装信息显示KSC223采用SOP8封装形式。
8523 0051000 价格&库存
很抱歉,暂时无法提供与“8523 0051000”相匹配的价格&库存,您可以联系我们找货
  • 1000+7.824101000+1.00938
