8719NH.00305
8719NH.00305
    BELDEN
    BELDEN - 8719NH.00305 - Multipair Cable, Screened, 1 Pair, 16 AWG
8719NH.00305 数据手册
TECHNICAL DATA SHEET 8719NH code version date page 8719NH 4 2007-02-14 1/2 APPLICATION Instrumentation and computer cable for data transmission applications. CONSTRUCTION 1. Conductor 2. Insulation 3. Foil 4. Drainwire 5. Sheath 1. 2. 3. 4. 5. Conductor Insulation Material Diameter over insulation Colour of insulation Foil Material Thickness Drainwire Sheath Material Colour Nominal diameter AWG16 (19xAWG29) tinned Cu Polyethylene 3.10 ± 0.07 mm Black and Transparent Aluminium / Polyester 9 / 23 µm AWG18 (16xAWG30) tinned Cu FRNC Chrome (like RAL 7037) 8.10 mm REQUIREMENTS AND TEST METHODS Electrical: Max. continuous current per conductor @ 25 ˚C Nominal capacitance conductors of pair @ 1 kHz Nominal capacitance conductor to shield @ 1 kHz * Nominal inductance of pairs Nominal resistance conductor Nominal resistance shield Nominal impedance 7A 75.4 pF/m 144.4 pF/m 0.66 µH/m 14.76 Ω/km 20.00 Ω/km 65 Ohm *One conductor to other conductor and shield. #Nominal Values are for information only. ã Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner TECHNICAL DATA SHEET 8719NH Mechanical and physical: Flame resistance Oil resistance Radiation resistance Application specification Halogen content according to IEC754-1 Corrosivity of fire gasses according to IEC754-2 Conductivity pH value Temperature range installing Temperature range operating (moving installation) Temperature range operating (fixed installation) Temperature range storage Nominal weight code version date page 8719NH 4 2007-02-14 2/2 IEC 60332-3C ASTMD741 IEC544 (CERN) BS 7655 section 6.1 table 1, LTS 3 zero ≤ 100 µS/cm ≥ 3.5 -15 to +80 ˚C -15 to +80 ˚C -45 to +80 ˚C -45 to +80 ˚C approx. 9.5 kg/100m PACKAGING On non-returnable reels with a nominal length of 1000m (-0, 0%). Each reel is labelled with the following data: Belden Logo. Belden code number. Item description. Length on the reel. Date of manufacture. CE-marking. Belden declares this product to be in compliance with the environmental regulations EU RoHS (Directive 2002/95/EC, 27 January 2003); this is valid for all material produced after the RoHS compliant date for this product. ã Belden Wire & Cable B.V. All rights are reserved. Reproduction in whole or in part is prohibited without the written consent of the copyright owner
8719NH.00305 价格&库存
很抱歉,暂时无法提供与“8719NH.00305”相匹配的价格&库存,您可以联系我们找货
