8761 06010000
8761 06010000
    BELDEN
    CBL 1PR 22AWG SHLD
8761 06010000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8761 Multi-Conductor - Single-Pair Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (7x30) TC conductors, polyethylene insulation, twisted pair, overall Beldfoil® shield (100% coverage), 22 AWG stranded TC drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 1 22 7x30 TC - Tinned Copper Total Number of Conductors: 2 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PE - Polyethylene 0.017 Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Beldfoil® Coverage (%) Tape Aluminum Foil-Polyester Tape w/shorting fold 100.000 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 Stranded TC - Tinned Copper Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .025 Overall Cable Overall Cabling Lay Length & Direction: Length (in.) Direction Twists (twist/ft) 2.000 Left Hand 6.000 Overall Nominal Diameter: 0.175 in. Pair Pair Color Code Chart: Number Color 1 Black & Clear Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C UL Temperature Rating: 60°C (UL AWM Style 2092) Bulk Cable Weight: 16 lbs/1000 ft. Max. Recommended Pulling Tension: 27 lbs. Min. Bend Radius/Minor Axis: 1.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CM NEC Articles: 800 CEC/C(UL) Specification: CM AWM Specification: UL Style 2092 (300 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8761 Multi-Conductor - Single-Pair Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: UL1685 UL Loading CSA Flame Test: FT1 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 88761, 87761, 82761 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 64 Nom. Inductance: Inductance (µH/ft) 0.2 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 24 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 47 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 16 Max. Operating Voltage - UL: Voltage 300 V RMS (UL AWM Style 2092) Max. Recommended Current: Description Current 10C temperature rise 2.9 Amps per conductor @ 25°C ambient Put Ups and Colors: Item # Putup Ship Weight Color 8761 060U1000 1,000 FT 17.000 LB CHROME Notes Item Desc 8761 060U500 500 FT 9.000 LB CHROME 8761 0601000 1,000 FT 18.000 LB CHROME C 2 #22 PE FS PVC 8761 06010000 10,000 FT 170.000 LB CHROME CY 2 #22 PE FS PVC 8761 06010001 10,000 FT 170.000 LB CHROME CZ 2 #22 PE FS PVC 8761 06015000 15,000 FT 270.000 LB CHROME CY 2 #22 PE FS PVC 8761 0602000 2,000 FT 36.000 LB CHROME 8761 060500 500 FT 9.000 LB CHROME 8761 0605000 5,000 FT 90.000 LB CHROME 2 #22 PE FS PVC 2 #22 PE FS PVC 2 #22 PE FS PVC 2 #22 PE FS PVC C 2 #22 PE FS PVC Notes: C = CRATE REEL PUT-UP. Y = FINAL PUT-UP LENGTH MAY VARY -10% TO +20% FROM LENGTH SHOWN.MAY CONTAIN 2 PIECES. MINIMUM LENGTH OF ANY ONE PIECE IS 1500'. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Page 2 of 3 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8761 Multi-Conductor - Single-Pair Cable Revision Number: 2 Revision Date: 08-02-2013 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 01-05-2017
8761 06010000 价格&库存
很抱歉,暂时无法提供与“8761 06010000”相匹配的价格&库存,您可以联系我们找货
