8791 060500
    BELDEN
    CBL 3COND 18AWG SHLD
8791 060500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8791 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: Overall spiral shield, 18 AWG stranded (7x26) tinned copper conductors, conductors cabled, PVC insulation, tinned copper spiral wrapped shield (80% shield coverage), PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Conductors AWG Stranding Conductor Material 3 18 7x26 TC - Tinned Copper Total Number of Conductors: 3 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride .022 Outer Shield Outer Shield Material: Type Outer Shield Material Coverage (%) Spiral Serve TC - Tinned Copper 80 Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .028 Overall Cable Overall Cabling Color Code Chart: Number Color 1 Black 2 Red 3 White Overall Nominal Diameter: 0.260 in. Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Bulk Cable Weight: 42 lbs/1000 ft. Max. Recommended Pulling Tension: 67 lbs. Min. Bend Radius/Minor Axis: 2.750 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Page 1 of 2 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 8791 Multi-Conductor - Audio, Control and Instrumentation Cable Capacitance (pF/ft) 47 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 84 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.9 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 16 Max. Operating Voltage - Non-UL: Voltage 450 V RMS Max. Recommended Current: Current 5.1 Amps per conductor at 25°C Put Ups and Colors: Item # Putup Ship Weight Color 8791 060U1000 1,000 FT 44.000 LB CHROME Notes Item Desc 8791 0601000 1,000 FT 46.000 LB CHROME C 3 #18 PVC SHLD PVC 8791 060500 500 FT 23.000 LB CHROME C 3 #18 PVC SHLD PVC 8791 0605000 5,000 FT 225.000 LB CHROME CZ 3 #18 PVC SHLD PVC TRANSFER REVIEW (20 TO 30) Notes: C = CRATE REEL PUT-UP. Z = FINAL PUT-UP LENGTH MAY VARY (+ OR -) 10% FOR SPOOLS OR REELS AND(+ OR -) 5% FOR UNREEL CARTONS FROM LENGTH SHOWN. Revision Number: 3 Revision Date: 09-26-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 08-26-2016
8791 060500 价格&库存
很抱歉,暂时无法提供与“8791 060500”相匹配的价格&库存,您可以联系我们找货
  • 500+38.99898500+4.87788
