9159 0601000
9159 0601000
    BELDEN
    CBL 5PR 18AWG
9159 0601000 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9159 Multi-Conductor - Audio, Control and Instrumentation Cable For more Information please call 1-800-Belden1 General Description: 18 AWG stranded (16x30) tinned copper conductors, PVC insulation, twisted pairs, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material 5 18 16x30 TC - Tinned Copper Total Number of Conductors: 10 Insulation Insulation Material: Insulation Material Wall Thickness (in.) PVC - Polyvinyl Chloride 0.013 Inner Shield Inner Shield Material: Inner Shield Material Unshielded Outer Shield Outer Shield Material: Outer Shield Material Unshielded Outer Jacket Outer Jacket Material: Outer Jacket Material Nom. Wall Thickness (in.) PVC - Polyvinyl Chloride .032 Overall Cable Overall Nominal Diameter: 0.391 in. Pair Pair Color Code Chart: Number Color 1 Black & Red 2 Black & White 3 Black & Green 4 Black & Blue 5 Black & Yellow Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +80°C Non-UL Temperature Rating: 80°C (UL AWM Style 2464) Bulk Cable Weight: 76 lbs/1000 ft. Max. Recommended Pulling Tension: 269 lbs. Min. Bend Radius/Minor Axis: 4 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CMG CEC/C(UL) Specification: CMG AWM Specification: UL Style 2464 (300 V 80°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes Page 1 of 2 01-05-2017 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9159 Multi-Conductor - Audio, Control and Instrumentation Cable EU Directive 2000/53/EC (ELV): Yes EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 04/01/2005 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test CSA Flame Test: FT4 Plenum/Non-Plenum Plenum (Y/N): No Electrical Characteristics (Overall) Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 25.5 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 5.86 Max. Operating Voltage - UL: Voltage 300 V RMS Max. Recommended Current: Current 3.4 Amps per conductor @ 20°C Put Ups and Colors: Item # Putup Ship Weight Color Notes Item Desc 9159 0601000 1,000 FT 99.000 LB CHROME C 5 #18 PR PVC FRPVC 9159 060500 500 FT 50.000 LB CHROME C 5 #18 PR PVC FRPVC Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 09-14-2012 © 2017 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 2 of 2 01-05-2017
9159 0601000
物料型号:9159 Multi-Conductor Cable
器件简介: - 导体:18 AWG(美国线规)的10对16x30股镀锡铜导体。 - 绝缘:PVC(聚氯乙烯)绝缘,壁厚0.013英寸。 - 内屏蔽:未屏蔽。 - 外屏蔽:未屏蔽。 - 外护套:PVC材料,标称壁厚0.032英寸。 - 电缆总体直径:0.391英寸。
引脚分配: - 配对颜色编码:1号为黑色和红色,2号为黑色和白色,3号为黑色和绿色,4号为黑色和蓝色,5号为黑色和黄色。
参数特性: - 工作温度范围:-20°C至+80°C。 - 非UL温度等级:80°C(UL AWM样式2464)。 - 电缆重量:每1000英尺76磅。 - 最大推荐拉力:269磅。 - 最小弯曲半径/次轴:4英寸。
功能详解: - 适用标准和机构合规性:符合NEC/(UL)规范、CEC/C(UL)规范、EU指令2011/65/EU(ROHS II)、EU CE标志等。 - 电气特性:导体对导体的标称电容为每英尺25.5皮法拉,最大操作电压为300V RMS,每导体最大推荐电流为3.4安培(20°C)。
应用信息: - 电缆适用于音频、控制和仪器应用。
封装信息: - 包装类型:1000英尺卷装,重量为99.000磅,颜色为铬色。
注意事项: - 贝尔登公司(Belden)保留随时更改信息和规格的权利,且不保证产品可用性。 - 该产品符合EU RoHS指令,但库存中可能包含符合性日期之前制造的材料。
9159 0601000 价格&库存
很抱歉,暂时无法提供与“9159 0601000”相匹配的价格&库存,您可以联系我们找货
