9182 010U500
9182 010U500
    BELDEN
    TWINAX 22AWG 150 OHM
9182 010U500 数据手册
Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9182 Twinax - Twinaxial Cable For more Information please call 1-800-Belden1 General Description: 22 AWG stranded (19x34) tinned copper conductors, Datalene® insulation, Duofoil® (100% Coverage) plus a stranded tinned copper drain wire, PVC jacket. Physical Characteristics (Overall) Conductor AWG: # Pairs AWG Stranding Conductor Material Dia. (in.) 1 22 19x34 TC - Tinned Copper .031 Total Number of Conductors: 2 Insulation Insulation Material: Insulation Trade Name Insulation Material Datalene® FHDPE - Foam High Density Polyethylene Outer Shield Outer Shield Material: Outer Shield Trade Name Type Outer Shield Material Duofoil® Coverage (%) Tape Aluminum Foil-Polyester Tape-Aluminum Foil 100 Outer Shield Drain Wire AWG: AWG Stranding Drain Wire Conductor Material 22 19x34 TC - Tinned Copper Outer Shield Drain Wire Diameter: .031 Outer Jacket Outer Jacket Material: Outer Jacket Material PVC - Polyvinyl Chloride Overall Cable Overall Nominal Diameter: 0.345 in. Pair Pair Color Code Chart: Number Color 1 Black & Yellow Pair Lay Length & Direction: Lay Length (in.) Lay Length Twists (twist/ft) 3.0 4 Mechanical Characteristics (Overall) Operating Temperature Range: -20°C To +60°C Bulk Cable Weight: 41 lbs/1000 ft. Max. Recommended Pulling Tension: 28 lbs. Min. Bend Radius/Minor Axis: 3.500 in. Applicable Specifications and Agency Compliance (Overall) Applicable Standards & Environmental Programs NEC/(UL) Specification: CL2X, CMX CEC/C(UL) Specification: CMX AWM Specification: UL Style 2668 (30 V 60°C) EU Directive 2011/65/EU (ROHS II): Yes EU CE Mark: Yes EU Directive 2000/53/EC (ELV): Yes Page 1 of 3 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9182 Twinax - Twinaxial Cable EU Directive 2002/95/EC (RoHS): Yes EU RoHS Compliance Date (mm/dd/yyyy): 01/01/2004 EU Directive 2002/96/EC (WEEE): Yes EU Directive 2003/11/EC (BFR): Yes CA Prop 65 (CJ for Wire & Cable): Yes MII Order #39 (China RoHS): Yes Flame Test UL Flame Test: VW-1 Suitability Suitability - Indoor: Yes Plenum/Non-Plenum Plenum (Y/N): No Plenum Number: 89182 Electrical Characteristics (Overall) Nom. Characteristic Impedance: Impedance (Ohm) 150 Nom. Inductance: Inductance (µH/ft) 0.293 Nom. Capacitance Conductor to Conductor: Capacitance (pF/ft) 8.8 Nom. Capacitance Cond. to Other Conductor & Shield: Capacitance (pF/ft) 16.5 Nominal Velocity of Propagation: VP (%) 78 Nominal Delay: Delay (ns/ft) 1.3 Nom. Conductor DC Resistance: DCR @ 20°C (Ohm/1000 ft) 17.750 Nominal Outer Shield DC Resistance: DCR @ 20°C (Ohm/1000 ft) 17.750 Nom. Attenuation: Freq. (MHz) Attenuation (dB/100 ft.) 1 0.4 10 1.2 50 2.7 100 4.3 200 6.2 400 8.8 Max. Operating Voltage - UL: Voltage 300 V RMS (CMX) 30 V RMS (UL AWM Style 2668) 150 V RMS (CL2X) Put Ups and Colors: Item # Putup Ship Weight Color 9182 010U500 500 FT 21.500 LB BLACK 9182 0101000 1,000 FT 44.000 LB BLACK C 2 #22 FHDPE SHLD PVC 9182 010500 500 FT 23.000 LB BLACK C 2 #22 FHDPE SHLD PVC 9182 0105000 5,000 FT 240.000 LB BLACK C 2 #22 FHDPE SHLD PVC Page 2 of 3 Notes Item Desc 2 #22 FHDPE SHLD PVC 08-26-2016 Detailed Specifications & Technical Data ENGLISH MEASUREMENT VERSION 9182 Twinax - Twinaxial Cable Notes: C = CRATE REEL PUT-UP. Revision Number: 3 Revision Date: 08-16-2012 © 2016 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with EU RoHS (Directive 2002/95/EC, 27-Jan-2003). Material manufactured prior to the compliance date may be in stock at Belden facilities and in our Distributor’s inventory. The information provided in this Product Disclosure, and the identification of materials listed as reportable or restricted within the Product Disclosure, is correct to the best of Belden’s knowledge, information, and belief at the date of its publication. The information provided in this Product Disclosure is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. This Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Belden declares this product to be in compliance with EU LVD (Low Voltage Directive 2014/35/EU). Page 3 of 3 08-26-2016
9182 010U500 价格&库存
很抱歉,暂时无法提供与“9182 010U500”相匹配的价格&库存,您可以联系我们找货
